Author Topic: ULX Rank Names  (Read 7085 times)
Offline shadowbeatsinc
ULX Rank Names
« on: November 24, 2013, 04:53:34 pm »
How do I make rank names show up in tab, colors etc... is it an addon? If so, where do i get it? Another thing, with every map players are able to move through props... any fixes? Thanks :)
Re: ULX Rank Names
« Reply #1 on: November 24, 2013, 05:03:11 pm »
UTeam (which is bundled with ULX) allows you to assign groups to ranks/teams and colors. UTeam only works in Sandbox gamemodes, though. You can configure UTeam through XGUI.
ULX does not stop people from moving through props. I think you're looking for UClip.
Re: ULX Rank Names
« Reply #2 on: November 24, 2013, 05:04:31 pm »
Ok, now how can I do that to TTT?
Re: ULX Rank Names
« Reply #3 on: November 24, 2013, 05:05:53 pm »
I'm not aware of any ULX addons that can do that; the problem is that setting ranks/teams in other gamemodes conflicts with the gamemode's regular operations.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: ULX Rank Names
« Reply #4 on: November 25, 2013, 07:40:50 pm »
Noclip should be disabled in TTT anyways, though like Megiddo said, you could use Uclip which is found in the Release section of the ulx forums. The rank name thing (aka Uteam) will not work in TTT tab scoreboard, unless you extremely modify it, though there really is no need to do that because you would most likely want to know the Dead from Alive people..
Re: ULX Rank Names
« Reply #5 on: November 25, 2013, 10:50:49 pm »
I believe the clipping through props occurs when the server is on a CS:S map, but doesn't have CS:S properly mounted to the server. If so, you probably will have to contact your server host about adding CS:S content to your server.
About the scoreboard ranks, there is a post about it on the forums right here.
« Last Edit: November 25, 2013, 10:54:02 pm by Decicus »
