Author Topic: What does this do?  (Read 6881 times)
Offline Cobalt
What does this do?
« on: November 30, 2013, 02:32:10 pm »
So when I'm coding a command for ULX, it seems like many things including silent echoes, and the setOpposite param don't work unless you have this:
command_name:addParam{ ULib.cmds.BoolArg, invisible=true }
So what exactly does that do?
Re: What does this do?
« Reply #1 on: November 30, 2013, 02:43:03 pm »
Silent echoes don't need the BoolArg. At least not when I've used it.
Although, if you're setting an opposite like for freeze (freeze has 3 parameters, calling player, target, boolean). The boolean is used to check if the Opposite command (unfreeze) or the normal command (freeze) is used. When the opposite is used, it's set to "_, _, true". Two first underscores are just to basically be the same as normal (calling player and target player), but the last one is to make the third parameter to "true", making it unfreeze.
It might be confusing (I'm tired), but basically: It's only needed for booleans, if you have something like "should_unfreeze", and then checks inside the command where it's like "if not should_unfreeze" (if should_unfreeze is false, basically, normal command).
Let's hope what I've understood is correct. Don't kill me if I'm wrong.
(My 200th post! Wooh!)
« Last Edit: November 30, 2013, 02:45:25 pm by Decicus »
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #2 on: November 30, 2013, 02:46:29 pm »
As I've said to other people before, I don't know too much about how the black magic of ulx works, but from what little knowledge of ulx, I do know what that does.
command_name obviously being command name such as god.
addParam, is basically calling arguments I believe. So in {} there would normally be like type=ULib.cmds.PlayersArg, meaning that there would be a list of all the players, and you can select one of them to do w/e you're going to do to them.
Then following the above command, you could gibe a string argument such as another param
command_name:addParam{ type=ULib.cmds.StringArg, hint="STRING VALUE" }
So that was my example of addParam, but I bet you weren't talking about that, and you were most likely talking about the two functions within the {}
Typically when you're calling Ulib.cmds.(w/e here) you usually have type= before Ulib.cmds
I do not know what the first one would do, but I could guess the second one would just make the list/string/args invisible.
EDIT:
Just to add on to the original post, after I added invisible to one of my custom made ulx scripts, it just errored out. So I have no clue what it does.
[Dev Apple|2|STEAM_0:0:35379784] Lua Error:
[ERROR] addons/ulx give weapon/lua/ulx/modules/sh/giveweapon.lua:50: '}' expecte
d near 'type'
  1. unknown - addons/ulx give weapon/lua/ulx/modules/sh/giveweapon.lua:0
« Last Edit: November 30, 2013, 02:55:21 pm by chaos13125 »
Offline Cobalt
« Reply #3 on: November 30, 2013, 03:18:15 pm »
No, I know all that stuff, I was referring to the actual "BoolArg, invisible=true" part.
« Reply #4 on: November 30, 2013, 06:01:17 pm »
Well I can tell you this, it breaks my server :p
« Reply #5 on: November 30, 2013, 08:55:10 pm »
When used properly, it's usually intended to prevent a variable from being seen, in most instances, in the chat window of a chat command.
As the ULib command structure is quite robust, it could be used for other instances.
If you'd like to give a specific example within ULX (or a mod you've seen) that it's been used, I'd be happy to review/verify for you.
Offline Cobalt
« Reply #6 on: December 01, 2013, 04:08:13 pm »
For example, I coded this a while ago:
  1. function ulx.sendlua( calling_ply, target_plys, lua, should_silent )
  2.         for k,v in pairs( target_plys ) do
  3.                 v:SendLua( lua )
  4.         end
  5.         if should_silent then
  6.                 ulx.fancyLogAdmin( calling_ply, true, "#A ran lua #s on #T", lua, target_plys )
  7.         else
  8.                 ulx.fancyLogAdmin( calling_ply, "#A ran lua #s on #T", lua, target_plys )
  9.         end
  10. end
  11. local sendlua = ulx.command( "Rcon", "ulx sendlua", ulx.sendlua )
  12. sendlua:addParam{ type=ULib.cmds.PlayersArg }
  13. sendlua:addParam{ type=ULib.cmds.StringArg, hint="string", ULib.cmds.takeRestOfLine }
  14. sendlua:addParam{ type=ULib.cmds.BoolArg, invisible=true }
  15. sendlua:defaultAccess( ULib.ACCESS_SUPERADMIN )
  16. sendlua:help( "Run a lua string on a client.\nssendlua = silent echo" )
  17. sendlua:setOpposite( "ulx ssendlua", { _, _, _, true } )
If I don't include the invisible boolarg, the opposite function won't work- Both buttons make the log echo not silent. Once I add the invisible boolarg, everything works like it should.
« Reply #7 on: December 01, 2013, 04:14:50 pm »
It's just telling ULib that the argument isn't really an player-specified argument at all, but some metadata that needs to be passed around. In this case, it's used so the target function can recognize if an "opposite" command has been specified.
I probably could've handled it better a different way, but this was easy at the time. (Unfortunately, ease does drive development sometimes...)
