Author Topic: Need automatic adding files to the res file  (Read 7421 times)
OmegaAlpha
« on: January 21, 2007, 04:55:14 pm »
We really need a plugin that you can tell what people to download. i hope someone gets me  ???
Re: Need automatic adding files to the res file
« Reply #1 on: January 21, 2007, 05:10:34 pm »
You understand that the only folder Gmod 10 lua allows writing to is /data, right?
There is no way for lua to write to /maps
Offline spbogie
« Reply #2 on: January 24, 2007, 01:08:12 pm »
Create an Lua script named something like "ForceDL.lua" and place it in your "garrysmod/lua/autorun/server" folder.
Add the following line to your script for each file you wish to send to the clients.
resource.AddFile("<path to file>")Replace <path to file> with the location of your file relative to the garrysmod root directory.
« Reply #3 on: January 24, 2007, 06:38:42 pm »
Thanks spbogie. I learn something new everyday witht this team.
