Author Topic: Help with superadmin death sound.  (Read 5903 times)
Offline jacob428
« on: December 17, 2013, 10:12:39 am »
I am trying to make it so a custom sound plays when a superadmin dies instead of the default death sounds. The wav is 44100/1441. It currently still plays from the regular deathsounds table. Any help would be appreciated! Also there are no errors currently.
From player.lua:
  1. local admindeathsound = Sound( "sound/fail.wav" )
  2.
  3. local function PlayDeathSound(victim)
  4.    if not IsValid(victim) then return end
  5.         if victim:IsSuperAdmin() then
  6.         sound.Play(admindeathsound, victim:GetShootPos(), 90, 100)
  7.         end
  8.         sound.Play(table.Random(deathsounds), victim:GetShootPos(), 90, 100)
  9. end
« Last Edit: December 17, 2013, 10:16:07 am by jacob428 »
Offline Cobalt
Re: Help with superadmin death sound.
« Reply #1 on: December 17, 2013, 11:20:54 am »
There was an 'end' where the 'else' was suppose to be.
  2.
  3. function PlayDeathSound( victim )
  4.
  5. if not IsValid( victim ) then
  6.         return
  7. end
  8.
  9. if victim:IsSuperAdmin() then
  10.         sound.Play( admindeathsound, victim:GetShootPos(), 90, 100 )
  11. else
  12.         sound.Play( table.Random( deathsounds ), victim:GetShootPos(), 90, 100 )
  13. end
  14.
  15. end
  16.
« Last Edit: December 17, 2013, 11:22:55 am by Cobalt77 »
Offline jacob428
« Reply #2 on: December 17, 2013, 11:25:54 am »
  2.
  4.
  6.         return
  7. end
  8.
  11. else
  13. end
  14.
  15. end
  16.
With this I get no sound on death, but still no errors. Do the wavs have to be somewhere special for sound.Play?
Offline Cobalt
« Reply #3 on: December 17, 2013, 11:28:36 am »
You have to put the file in the sound/ directory, run a websync/whatever fastdl thing you have, and do a resource.AddFile for the filename anywhere in lua/autorun
Just to be sure, you have this function hooked, right? I assumed you already had it hooked somewhere else in your file.
Offline jacob428
« Reply #4 on: December 17, 2013, 11:36:05 am »
It is hooked, synced and resourced. The wav works fine with the ulx playsound command, but doesn't play on death.
« Last Edit: December 17, 2013, 11:55:00 am by jacob428 »
« Reply #5 on: December 17, 2013, 04:44:04 pm »
Reasonably sure Sound() and sound.Play default to the ./sound/ folder, yet, you have the folder specified in the variable.
I'm surprised you're not seeing a 'unable to precache file fail.wav' at client connect on the client side.
My theory, you're trying to play gmod/sound/sound/fail.wav when it should be gmod/sound/fail.wav
Try Sound( "fail.wav" ) instead of Sound( "sound/fail.wav" )
Offline jacob428
« Reply #6 on: December 17, 2013, 06:31:29 pm »
My friend, you've hit the nail on the head. Just changed sound/fail.wav to fail.wav and it works perfectly. Thank you so much!
« Reply #7 on: December 17, 2013, 07:52:37 pm »
Welcome. Glad our community could be of assistance.
