Hiding admin commands from users
Topic: Hiding admin commands from users (Read 4255 times)
Pro_instinct
December 21, 2013, 08:15:27 am »
Hey guys I was just wondering if its possible to hide commands from other users say if I !kick "username" I don't want !kick "username" showing in the chat. I just want them to be kicked. Any support is appreciated, thanks in advance! -Instinct
Last Edit: December 21, 2013, 08:42:42 am by Pro_instinct
Megiddo
Ulysses Team Member
Project Lead
Re: Hiding admin commands from users
December 21, 2013, 09:07:22 am »
Run it in console instead.
Cobalt
Full Member
http://steamcommunity.com/id/__yvl/
Reply #2 on:
December 21, 2013, 09:53:13 am »
In the lua, where you see
local
kick
ulx
command
"Utility"
"ulx kick"
ulx
kick
"!kick"
change it to
local
kick
ulx
command
"Utility"
"ulx kick"
ulx
kick
"!kick"
true
Pro_instinct
Reply #3 on:
December 21, 2013, 10:01:33 am »
Where exactly do I find this piece of code to edit it?
MrPresident
Ulysses Team Member
Reply #4 on:
December 21, 2013, 12:36:18 pm »
garrysmod/addons/ULX/lua/ulx/modules/sh/util.lua
Be warned though.. we never recommend modifying base ULX files because:
1. You might break everything (so backup the file before you modify it)
2. When you update ULX you will lose all of your modifications.
There is no alternative way to modify the function without modifying the base file though. Good luck!
Storm
Full Member
Reply #5 on:
December 21, 2013, 02:51:02 pm »
I just go to the commands echo tab and turn off the echo. It takes about 6 seconds.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #6 on:
December 21, 2013, 05:17:56 pm »
Why must everyone be so complicated?
Like Megiddo answered, open up the console and type "ulx <command> <player>"
Most commands will never be echoed that way, especially if the echo mode is set to anonymous.
