Author Topic: Change sv_gravity  (Read 5766 times)
Offline simpleee
Change sv_gravity
« on: December 21, 2013, 08:16:54 am »
Hello,
How can i change the world gravity with lua?
Re: Change sv_gravity
« Reply #1 on: December 21, 2013, 08:41:55 am »
I believe you would use something like RunConsoleCommand
Something like this:
  1. RunConsoleCommand( "sv_gravity", 600 )
« Reply #2 on: December 21, 2013, 04:48:45 pm »
http://wiki.garrysmod.com/page/Global/RunConsoleCommand
Though the mauritis site in this case was correct, it hosts the mostly Gmod lua commands prior to Gmod13.
Gmod 13 changed A LOT of G-Lua, so I'd recommend searching it before using the mauritis commands.
« Reply #3 on: December 21, 2013, 05:58:46 pm »
I know, JamminR. I double-checked with the official wiki. It's just in this case I like Maurits' layout better, and since I knew it worked as it should then I linked it.
Offline TheAndroid1
« Reply #4 on: December 22, 2013, 05:54:32 am »
That is right, except the 600 needs to be a string.
« Reply #5 on: December 22, 2013, 06:07:49 am »
Pretty sure numbers aren't restricted to that. I just tested without the quotes (aka not as a string), and it works fine.
