Author Topic: Spawning problem  (Read 10061 times)
Offline Kawo
Spawning problem
« on: December 27, 2013, 03:20:07 am »
Hello
I know that my problem is not related to ULX or something in around this topic but I need help.
I started my own TTT server. Everything is fine, but not spawns. After the round has ended, people spawn where they were on spectator. I have no idea what I should show you to help you helping me. Sorry for my grammar and other stuff. Thanks
Offline jackg904
Re: Spawning problem
« Reply #1 on: December 27, 2013, 10:27:59 am »
I had this issue, found it to be related to a Coderhire Addon named "TrueTTT" If you remove that, I have a feeling the issue will be sorted.
Offline Kawo
« Reply #2 on: December 27, 2013, 11:44:32 am »
But I don't have that addon. I got cannibalism, defibrillator, awp, tripwire, turret and the crossbow.
Offline Cobalt
« Reply #3 on: December 27, 2013, 11:47:46 am »
Start removing addons one by one and restarting the server until it starts working again. That's usually what I do when I have problems like that.
Offline Kawo
« Reply #4 on: December 27, 2013, 12:52:32 pm »
I tried and it did not work :/
« Reply #5 on: December 27, 2013, 03:20:18 pm »
Define "it did not work"
Offline Kawo
« Reply #6 on: December 28, 2013, 02:01:55 am »
Nothing changed. Everyone still spawns where they were on spectator.
Offline Neku
« Reply #7 on: December 28, 2013, 02:46:33 am »
Can I see the lua of the defibrillator and the cannibalism mod?
Since defib has to do with spawning people where they died,
I would expect that to be the issue.
And as for cannibalism, I'm not sure.
Have you tried removing the defib yet?
If that doesn't work, perhaps remove cannibalism.
Offline Kawo
« Reply #8 on: December 28, 2013, 03:32:22 am »
Defib:
if SERVER then
  resource.AddFile("materials/vgui/ttt/icon_rg_defibrillator.png")
local STATE_NONE, STATE_PROGRESS, STATE_ERROR = 0, 1, 2
local color_red = Color(255, 0, 0)
SWEP.Base = "weapon_tttbase"
SWEP.HoldType = "slam"
SWEP.ViewModel = Model("models/weapons/v_c4.mdl")
SWEP.WorldModel = Model("models/weapons/w_c4.mdl")
--- TTT Vars
SWEP.Kind = WEAPON_EQUIP2
SWEP.AutoSpawnable = false
SWEP.CanBuy = {ROLE_TRAITOR}
SWEP.LimitedStock = true
if CLIENT then
  SWEP.PrintName = "Defibrillator"
  SWEP.Slot = 7
  SWEP.Icon = "vgui/ttt/icon_rg_defibrillator.png"
  SWEP.EquipMenuData = {
    type = "item_weapon",
    name = "Defribrillator",
    desc = "Resurrect dead mates with this one!"
  surface.CreateFont("DefibText", {
    font = "Tahoma",
    size = 13,
    weight = 700,
    shadow = true
  function SWEP:DrawHUD()
    local state = self:GetDefibState()
    local scrW, scrH = ScrW(), ScrH()
    local progress = 1
    local outlineCol, progressCol, progressText = color_white, color_white, ""
    if state == STATE_PROGRESS then
      local startTime, endTime = self:GetDefibStartTime(), self:GetDefibStartTime() + 5
      progress = math.TimeFraction(startTime, endTime, CurTime())
      if progress <= 0 then
        return
      outlineCol = Color(0, 100, 0)
      progressCol = Color(0, 255, 0, (math.abs(math.sin(RealTime() * 3)) * 100) + 20)
      progressText = self:GetStateText() or "DEFIBRILLATING"
    elseif state == STATE_ERROR then
      outlineCol = color_red
      progressCol = Color(255, 0, 0, math.abs(math.sin(RealTime() * 15)) * 255)
      progressText = self:GetStateText() or ""
      return
    progress = math.Clamp(progress, 0, 1)
    surface.SetDrawColor(outlineCol)
    surface.DrawOutlinedRect(scrW / 2 - (200 / 2) - 1, scrH / 2 + 10 - 1, 202, 16)
    surface.SetDrawColor(progressCol)
    surface.DrawRect(scrW / 2  - (200 / 2), scrH / 2 + 10, 200 * progress, 14)
    surface.SetFont("DefibText")
    local textW, textH = surface.GetTextSize(progressText)
    surface.SetTextPos(scrW / 2 - 100 + 2, scrH / 2 - 20 + textH)
    surface.SetTextColor(color_white)
    surface.DrawText(progressText)
function SWEP:SetupDataTables()
  self:NetworkVar("Int", 0, "DefibState")
  self:NetworkVar("Float", 1, "DefibStartTime")
  self:NetworkVar("String", 0, "StateText")
function SWEP:Initialize()
  self:SetDefibState(STATE_NONE)
  self:SetDefibStartTime(0)
function SWEP:Deploy()
  return true
function SWEP:Holster()
  return true
function SWEP:PrimaryAttack()
  if CLIENT then return end
  local tr = util.TraceLine({
    start = self.Owner:EyePos(),
    endpos = self.Owner:EyePos() + self.Owner:GetAimVector() * 80,
    filter = self.Owner
  if IsValid(tr.Entity) and tr.Entity:GetClass() == "prop_ragdoll" then
    if not tr.Entity.uqid then
      self:FireError("FAILURE - SUBJECT BRAINDEAD")
      return
    local ply = player.GetByUniqueID(tr.Entity.uqid)
    if IsValid(ply) then
      self:BeginDefib(ply, tr.Entity)
      return
    self:FireError("FAILURE - INVALID TARGET")
function SWEP:BeginDefib(ply, ragdoll)
  local spawnPos = self:FindPosition(self.Owner)
  if not spawnPos then
    self:FireError("FAILURE - INSUFFICIENT ROOM")
    return
  self:SetStateText("DEFIBRILLATING - "..string.upper(ply:Name()))
  self:SetDefibState(STATE_PROGRESS)
  self:SetDefibStartTime(CurTime())
  self.TargetPly = ply
  self.TargetRagdoll = ragdoll
  self:SetNextPrimaryFire(CurTime() + 6)
function SWEP:FireError(err)
  if err then
    self:SetStateText(err)
    self:SetStateText("")
  self:SetDefibState(STATE_ERROR)
  timer.Simple(1, function()
    if IsValid(self) then
  end)
  self:SetNextPrimaryFire(CurTime() + 1.2)
function SWEP:FireSuccess()
  self:SetNextPrimaryFire(CurTime() + 1)
  hook.Call("UsedDefib", GAMEMODE, self.Owner)
  self:Remove()
function SWEP:Think()
  if self:GetDefibState() == STATE_PROGRESS then
    if not IsValid(self.Owner) then
      self:FireError()
      return
    if not (IsValid(self.TargetPly) and IsValid(self.TargetRagdoll)) then
      self:FireError("ERROR - SUBJECT BRAINDEAD")
      return
      filter = self.Owner
    if tr.Entity ~= self.TargetRagdoll then
      self:FireError("ERROR - TARGET LOST")
      return
    if CurTime() >= self:GetDefibStartTime() + 5 then
      if self:HandleRespawn() then
        self:FireSuccess()
        self:FireError("ERROR - INSUFFICIENT ROOM")
        return
    self:NextThink(CurTime())
    return true
function SWEP:HandleRespawn()
  local ply, ragdoll = self.TargetPly, self.TargetRagdoll
    return false
  local credits = CORPSE.GetCredits(ragdoll, 0)
  ply:SpawnForRound(true)
  ply:SetCredits(credits)
  ply:SetPos(spawnPos)
  ply:SetEyeAngles(Angle(0, ragdoll:GetAngles().y, 0))
  ragdoll:Remove()
  return true
local Positions = {}
for i=0,360,22.5 do table.insert( Positions, Vector(math.cos(i),math.sin(i),0) ) end -- Populate Around Player
table.insert(Positions, Vector(0, 0, 1)) -- Populate Above Player
function SWEP:FindPosition(ply)
  local size = Vector(32, 32, 72)
  local StartPos = ply:GetPos() + Vector(0, 0, size.z/2)
  local len = #Positions
  for i = 1, len do
    local v = Positions[i]
    local Pos = StartPos + v * size * 1.5
    local tr = {}
    tr.start = Pos
    tr.endpos = Pos
    tr.mins = size / 2 * -1
    tr.maxs = size / 2
    local trace = util.TraceHull(tr)
    if(not trace.Hit) then
      return Pos - Vector(0, 0, size.z/2)
  return false
EDIT -JamminR - Use code tags to keep the post tidy.
« Last Edit: December 28, 2013, 08:16:30 am by JamminR »
Offline Kawo
« Reply #9 on: December 28, 2013, 03:34:27 am »
Cannibalism :
if SERVER then
AddCSLuaFile( "shared.lua" )
resource.AddFile("materials/vgui/ttt/ttt_cannibalism.vmt")
resource.AddFile("materials/vgui/ttt/ttt_cannibalism.vtf")
if CLIENT then
SWEP.PrintName = "Cannibalism"
SWEP.Slot      = 7 -- add 1 to get the slot number key
SWEP.ViewModelFOV  = 72
SWEP.ViewModelFlip = true
-- Always derive from weapon_tttbase.
--- Standard GMod values
SWEP.HoldType = "melee"
SWEP.Primary.Delay       = 10
SWEP.Primary.Recoil      = 0
SWEP.Primary.Automatic   = false
SWEP.Primary.Damage      = 0
SWEP.Primary.Cone        = 0.025
SWEP.Primary.Ammo        = ""
SWEP.Primary.ClipSize    = 1
SWEP.Primary.ClipMax     = 1
SWEP.Primary.DefaultClip = 1
SWEP.IronSightsPos = Vector( 6.05, -5, 2.4 )
SWEP.IronSightsAng = Vector( 2.2, -0.1, 0 )
SWEP.ViewModel  = "models/weapons/v_knife_t.mdl"
SWEP.WorldModel = "models/weapons/w_knife_t.mdl"
function SWEP:ShouldDropOnDie()
self:Remove()
function SWEP:OnDrop()
self:Remove()
if not self:CanPrimaryAttack() then return end
self.Weapon:SetNextPrimaryFire( CurTime() + self.Primary.Delay )
local tracedata = {}
tracedata.start = self.Owner:GetShootPos()
tracedata.endpos = self.Owner:GetShootPos() + (self.Owner:GetAimVector() * 100)
tracedata.filter = self.Owner
tracedata.mins = Vector(1,1,1) * -10
tracedata.maxs = Vector(1,1,1) * 10
tracedata.mask = MASK_SHOT_HULL
local tr = util.TraceHull( tracedata )
local ply = self.Owner
if IsValid(tr.Entity) then
if tr.Entity.player_ragdoll then
timer.Simple(0.1, function()
    ply:Freeze(true)
    ply:SetColor(Color(255,0,0,255))
end)
          self.Weapon:SendWeaponAnim(ACT_VM_PRIMARYATTACK)
          timer.Create("GivePlyHealth_"..self.Owner:UniqueID(),0.5,6,function() self.Owner:SetHealth(self.Owner:Health()+5) end)
timer.Simple(3.1, function()
ply:Freeze(false)
ply:SetColor(Color(255,255,255,255))
          tr.Entity:Remove()
          self:Remove()
end )
--- TTT config values
-- Kind specifies the category this weapon is in. Players can only carry one of
-- each. Can be: WEAPON_... MELEE, PISTOL, HEAVY, NADE, CARRY, EQUIP1, EQUIP2 or ROLE.
-- Matching SWEP.Slot values: 0      1       2     3      4      6       7        8
-- If AutoSpawnable is true and SWEP.Kind is not WEAPON_EQUIP1/2, then this gun can
-- be spawned as a random weapon. Of course this AK is special equipment so it won't,
-- but for the sake of example this is explicitly set to false anyway.
-- The AmmoEnt is the ammo entity that can be picked up when carrying this gun.
SWEP.AmmoEnt = ""
-- CanBuy is a table of ROLE_* entries like ROLE_TRAITOR and ROLE_DETECTIVE. If
-- a role is in this table, those players can buy this.
-- InLoadoutFor is a table of ROLE_* entries that specifies which roles should
-- receive this weapon as soon as the round starts. In this case, none.
SWEP.InLoadoutFor = nil
-- If LimitedStock is true, you can only buy one per round.
-- If AllowDrop is false, players can't manually drop the gun with Q
SWEP.AllowDrop = true
-- If IsSilent is true, victims will not scream upon death.
SWEP.IsSilent = false
-- If NoSights is true, the weapon won't have ironsights
SWEP.NoSights = true
-- Equipment menu information is only needed on the client
if CLIENT then
-- Path to the icon material
SWEP.Icon = "vgui/ttt/ttt_cannibalism"
-- Text shown in the equip menu
type = "Weapon",
desc = "CANNIBALISM! GET RID OF EVIDENCE AND GAIN HEALTH!"
« Last Edit: December 28, 2013, 08:17:39 am by JamminR »
Offline Neku
« Reply #10 on: December 28, 2013, 04:38:47 pm »
I've used those two sweps on my own local server with a bot, and it seems
they are not the problem.
Are there any other mods you have? Besides sweps.
Offline Kawo
« Reply #11 on: December 29, 2013, 02:48:17 am »
I have RDM Manager, joining/leaving messages, mapvote and ULX Admin Mod
Offline Neku
« Reply #12 on: December 29, 2013, 11:31:08 am »
Try removing each of those one by one and test each time.
Don't remove ULX though.
