General
Off-Topic
Act dance?
Topic: Act dance? (Read 8555 times)
Kossan
Act dance?
January 02, 2014, 05:55:46 am »
Hello how do i fix act dance the act plugin to gmod? Or where is the plugin? Just need it plz help
MrPresident
Ulysses Team Member
Re: Act dance?
January 03, 2014, 05:13:08 am »
The act commands were built into garry's mod by default. There isn't a plugin for it as far as I know. What is wrong with yours?
Bytewave
Respected Community Member
Re: Act dance?
Reply #2 on:
January 03, 2014, 10:52:39 am »
He could be running TTT...
BKU disabled the act command in Trouble in Terrorist Town because players would abuse it to glitch their hitboxes.
Kossan, is this the case? Are you running TTT on your server, or is this another gamemode?
Kossan
Re: Act dance?
Reply #3 on:
January 05, 2014, 08:04:06 am »
ttt server
Bytewave
Re: Act dance?
Reply #4 on:
January 05, 2014, 12:37:39 pm »
Yep, my suspicions were correct.
Bad King disabled the act command in TTT revision 30 because of the glitchy hitbox bug it causes, giving players an unfair advantage.
If you go onto BKU's Git repo, you might be able to find the code change between v29 and v30 and modify your code to reflect it.
This is the TTT git repo.
If you need anything else, just ask.
General
Off-Topic
Act dance?
