Author Topic: UMaps - change map at specified time  (Read 92307 times)
Offline compuwiz
Re: UMaps - change map at specified time
« Reply #30 on: April 06, 2009, 06:59:16 pm »
When I type timeleft in chat it says I don't have access to the command. I am in the superadmin group with immunity. Everything in ULX works fine.
Offline benbrooks
« Reply #31 on: April 11, 2009, 05:41:35 am »
Probably a recent update that has done this, But I'll just let you know that these get sent to client's consoles every second.
Warning: Unhandled usermessage 'UMaps_timer'
Offline igiz
« Reply #32 on: February 17, 2010, 05:18:22 pm »
I know this topic has been inactive for a long while but I just want to say that recent gmod update broke it.When you type in !timeleft nothing shows up like it used to.Although it does changed the map after specified time,but its annoying as users are unable to check when the map is going to change.Anyway som1 could fix this?
« Reply #33 on: February 17, 2010, 07:23:04 pm »
What errors occur in server (and or) game console when you type !timeleft
Also, are there any errors when server starts regaring Umaps
Not only has GMod been updated, if you're using SVN, it's possible ULib updates have broken it too.
Using ULib svn?
Offline dracotonisamond
« Reply #34 on: March 13, 2010, 07:20:24 pm »
ULib\modules\UMaps/init.lua:252:attept to call feild 'concommand'' (a nill value)  off a fresh install with an edited umaps maps file.
happens after UMaps.lua loads.
havn't tested if it causes the addon to fail yet, but i will return with news if it does
EDIT: whoops,  didnt see this was so old.  but still, could be usefull as i dont know of any other map cycler.
« Last Edit: March 13, 2010, 07:27:48 pm by dracotonisamond »
« Reply #35 on: March 13, 2010, 10:55:28 pm »
Using ULib svn?
Offline igiz
« Reply #36 on: April 05, 2010, 05:49:28 pm »
This addon is great,just sucks that it is partially broken.I though maybe somebody can fix it.
The addon works fine the only function broken is the !timeleft function which does nothing now.When you type in chat !timeleft I get this error in my console:
RROR: Hook 'UMaps.playerSay' tried to call a nil function!
Removing Hook 'UMaps.playerSay'
Can somebody fix this old but good addon :)
Offline strategos
  • I wanna be the guy
    • Community
« Reply #37 on: October 23, 2011, 11:27:39 pm »
Does this still work or is there something like it?
