Author Topic: Lua error  (Read 7076 times)
Offline ojbristow
    • Superclocked
Lua error
« on: January 04, 2014, 01:42:51 pm »
Hello,
When I try to add someone to the rank 'TTTAdmin' everything is fine until someone views the 'Scoreboard'.  When you try to view the scoreboard and a TTTAdmin is online you will get kicked.  Here is the error:
[[SPCL] Owen|2|STEAM_0:1:50719053] Lua Error:
[ERROR] lua/vgui/dlabel.lua:68: bad key to string index (number expected, got string)
1. error - [C]:-1
2. __index - lua/includes/extensions/string.lua:262
3. ApplySchemeSettings - lua/vgui/dlabel.lua:68
4. unknown - lua/vgui/dlabel.lua:74
I have never edited anything in the sting.lua and dlabel.lua. I have noidea how to fix this, any help would be much appreciated!
Thanks,
Owen
Re: Lua error
« Reply #1 on: January 04, 2014, 01:52:56 pm »
Do you have a custom scoreboard with ranks or something? If so, copy/paste the gamemodes/terrortown/gamemode/vgui/sb_row.lua.
Use the code BB code.
Offline Neku
Re: Lua error
« Reply #2 on: January 04, 2014, 03:12:47 pm »
If you are using the default TTT scoreboard, you can't just edit the sb_row.
You must also configure the sb_main as well.
A simple Google search will net you the code for both.
Offline ojbristow
    • Superclocked
Re: Lua error
« Reply #3 on: January 04, 2014, 03:18:10 pm »
I have the set the scoreboard up properly, probably should have said that in the first post, it is working for the rest of the ranks.
Thanks,
Owen
Offline Neku
Re: Lua error
« Reply #4 on: January 04, 2014, 03:29:21 pm »
Thanks,
Owen
In that case, post your sb_row.Lua for me please.
Offline ojbristow
    • Superclocked
Re: Lua error
« Reply #5 on: January 04, 2014, 03:31:44 pm »
---- Scoreboard player score row, based on sandbox version
include("sb_info.lua")
local GetTranslation = LANG.GetTranslation
local GetPTranslation = LANG.GetParamTranslation
SB_ROW_HEIGHT = 24 --16
local PANEL = {}
function PANEL:Init()
   -- cannot create info card until player state is known
   self.info = nil
   self.open = false
   self.cols = {}
   self.cols[1] = vgui.Create("DLabel", self)
   self.cols[1]:SetText(GetTranslation("sb_ping"))
   self.cols[2] = vgui.Create("DLabel", self)
   self.cols[2]:SetText(GetTranslation("sb_deaths"))
   self.cols[3] = vgui.Create("DLabel", self)
   self.cols[3]:SetText(GetTranslation("sb_score"))
  self.cols[5] = vgui.Create("DLabel", self)
  self.cols[5]:SetText("Rank")
   if KARMA.IsEnabled() then
      self.cols[4] = vgui.Create("DLabel", self)
      self.cols[4]:SetText(GetTranslation("sb_karma"))
   for _, c in ipairs(self.cols) do
      c:SetMouseInputEnabled(false)
   self.tag = vgui.Create("DLabel", self)
   self.tag:SetText("")
   self.tag:SetMouseInputEnabled(false)
   self.sresult = vgui.Create("DImage", self)
   self.sresult:SetSize(16,16)
   self.sresult:SetMouseInputEnabled(false)
   self.avatar = vgui.Create( "AvatarImage", self )
   self.avatar:SetSize(SB_ROW_HEIGHT, SB_ROW_HEIGHT)
   self.avatar:SetMouseInputEnabled(false)
   self.nick = vgui.Create("DLabel", self)
   self.nick:SetMouseInputEnabled(false)
   self.voice = vgui.Create("DImageButton", self)
   self.voice:SetSize(16,16)
   self:SetCursor( "hand" )
----EDIT THESE TO ADD MORE COLOURS----
----Example: test = COLOR_BLUE----
---Make sure to put a comma after each line until the end (Last one doesn't have one---
local namecolor = {
   default = COLOR_WHITE,
   admin = Color(220, 180, 0, 255),
   dev = Color(100, 240, 105, 255),
   owner = Color(255, 255, 0, 255),
   member = Color(0, 255, 255),
   trustedmember = Color(0, 139, 139),
   donator = Color(255, 165, 0),
   tttmod = Color(255, 182, 193),
   globalmod = Color(255, 20, 147),
   supporter = Color(0, 128, 0),
   trustedadmin = Color(0, 0, 139),
   tttadmin = Color(0, 0, 255)
function GM:TTTScoreboardColorForPlayer(ply)
   if not IsValid(ply) then return namecolor.default end
   --ADD NAMECOLOURS HERE--
   if ply:SteamID() == "STEAM_0:0:1963640" then
      return namecolor.dev
   elseif ply:IsAdmin() and GetGlobalBool("ttt_highlight_admins", true) then
      return namecolor.admin
   elseif ply:IsUserGroup("superadmin") then
      return namecolor.owner
   elseif ply:IsUserGroup("TTTMod") then
  return namecolor.tttmod
local function ColorForPlayer(ply)
   if IsValid(ply) then
      local c = hook.Call("TTTScoreboardColorForPlayer", GAMEMODE, ply)
      -- verify that we got a proper color
      if c and type(c) == "table" and c.r and c.b and c.g and c.a then
         return c
         ErrorNoHalt("TTTScoreboardColorForPlayer hook returned something that isn't a color!\n")
function PANEL:Paint()
   if not IsValid(self.Player) then return end
--   if ( self.Player:GetFriendStatus() == "friend" ) then
--      color = Color( 236, 181, 113, 255 )
--   end
   local ply = self.Player
   if ply:IsTraitor() then
      surface.SetDrawColor(255, 0, 0, 30)
      surface.DrawRect(0, 0, self:GetWide(), SB_ROW_HEIGHT)
   elseif ply:IsDetective() then
      surface.SetDrawColor(0, 0, 255, 30)
   if ply == LocalPlayer() then
      surface.SetDrawColor( 200, 200, 200, math.Clamp(math.sin(RealTime() * 2) * 50, 0, 100))
      surface.DrawRect(0, 0, self:GetWide(), SB_ROW_HEIGHT )
   return true
function PANEL:SetPlayer(ply)
   self.Player = ply
   self.avatar:SetPlayer(ply)
   if not self.info then
      local g = ScoreGroup(ply)
      if g == GROUP_TERROR and ply != LocalPlayer() then
         self.info = vgui.Create("TTTScorePlayerInfoTags", self)
         self.info:SetPlayer(ply)
         self:InvalidateLayout()
      elseif g == GROUP_FOUND or g == GROUP_NOTFOUND then
         self.info = vgui.Create("TTTScorePlayerInfoSearch", self)
   self.voice.DoClick = function()
                           if IsValid(ply) and ply != LocalPlayer() then
                              ply:SetMuted(not ply:IsMuted())
   self:UpdatePlayerData()
function PANEL:GetPlayer() return self.Player end
function PANEL:UpdatePlayerData()
   self.cols[1]:SetText(ply:Ping())
   self.cols[2]:SetText(ply:Deaths())
   self.cols[3]:SetText(ply:Frags())
   if self.cols[4] then
      self.cols[4]:SetText(math.Round(ply:GetBaseKarma()))
   self.nick:SetText(ply:Nick())
   self.nick:SizeToContents()
   self.nick:SetTextColor(ColorForPlayer(ply))
        if ply:IsUserGroup("Member") then
                self.cols[5]:SetText("Member")
                self.cols[5]:SetTextColor(namecolor.member)
elseif ply:IsUserGroup("user") then
self.cols[5]:SetText("Guest")
self.cols[5]:SetTextColor(namecolor.default)
        elseif ply:IsUserGroup("Owner") then
        self.cols[5]:SetText("Owner")
self.cols[5]:SetTextColor(Color(255, 255, 0,255))
elseif ply:IsUserGroup("Superadmin") then
self.cols[5]:SetTextColor(namecolor.owner)
        elseif ply:IsUserGroup("TrustedMember") then
    self.cols[5]:SetText("Trusted Member")
self.cols[5]:SetTextColor(namecolor.trustedmember)
elseif ply:IsUserGroup("Donator") then
self.cols[5]:SetText("Donator")
self.cols[5]:SetTextColor(namecolor.donator)
self.cols[5]:SetText("TTT Mod")
self.cols[5]:SetTextColor(namecolor.tttmod)
elseif ply:IsUserGroup("GlobalMod") then
self.cols[5]:SetText("Global Mod")
self.cols[5]:SetTextColor(namecolor.globalmod)
        elseif ply:IsUserGroup("Supporter") then
                self.cols[5]:SetText("Supporter")
                self.cols[5]:SetTextColor(namecolor.supporter)
elseif ply:IsUserGroup("TrustedAdmin") then
self.cols[5]:SetText("Trusted Admin")
self.cols[5]:SetTextColor(namecolor.trustedadmin)
elseif ply:IsUserGroup("TTTAdmin") then
self.cols[5]:SetText("TTT Admin")
self.cols[5]:SetTextColor("namecolor.tttadmin")
--      elseif ply:IsUserGroup("admin") then
--              self.cols[5]:SetText("Admin")
--              self.cols[5]:SetTextColor(Color(220, 180, 0, 255))
--  Delete the -- and change the settings to your liking. DO NOT DELETE THE 'end'
   local ptag = ply.sb_tag
   if ScoreGroup(ply) != GROUP_TERROR then
      ptag = nil
   self.tag:SetText(ptag and GetTranslation(ptag.txt) or "")
   self.tag:SetTextColor(ptag and ptag.color or COLOR_WHITE)
   self.sresult:SetVisible(ply.search_result != nil)
   -- more blue if a detective searched them
   if ply.search_result and (LocalPlayer():IsDetective() or (not ply.search_result.show)) then
      self.sresult:SetImageColor(Color(200, 200, 255))
   -- cols are likely to need re-centering
   self:LayoutColumns()
   if self.info then
      self.info:UpdatePlayerData()
   if self.Player != LocalPlayer() then
      local muted = self.Player:IsMuted()
      self.voice:SetImage(muted and "icon16/sound_mute.png" or "icon16/sound.png")
      self.voice:Hide()
function PANEL:ApplySchemeSettings()
   for k,v in pairs(self.cols) do
      v:SetFont("treb_small")
      v:SetTextColor(COLOR_WHITE)
   self.nick:SetFont("treb_small")
   self.nick:SetTextColor(ColorForPlayer(self.Player))
   local ptag = self.Player and self.Player.sb_tag
   self.tag:SetFont("treb_small")
   self.sresult:SetImage("icon16/magnifier.png")
   self.sresult:SetImageColor(Color(170, 170, 170, 150))
function PANEL:LayoutColumns()
   for k,v in ipairs(self.cols) do
      v:SizeToContents()
      v:SetPos(self:GetWide() - (50*k) - v:GetWide()/2, (SB_ROW_HEIGHT - v:GetTall()) / 2)
      if v == self.cols[5] then
        v:SetPos(self:GetWide() - (85*k) - v:GetWide()/2, (SB_ROW_HEIGHT - v:GetTall()) / 2)
   self.tag:SizeToContents()
   self.tag:SetPos(self:GetWide() - (50 * 6) - self.tag:GetWide()/2, (SB_ROW_HEIGHT - self.tag:GetTall()) / 2)
   self.sresult:SetPos(self:GetWide() - (50*6) - 8, (SB_ROW_HEIGHT - 16) / 2)
function PANEL:PerformLayout()
   self.avatar:SetPos(0,0)
   self.avatar:SetSize(SB_ROW_HEIGHT,SB_ROW_HEIGHT)
   if not self.open then
      self:SetSize(self:GetWide(), SB_ROW_HEIGHT)
      if self.info then self.info:SetVisible(false) end
   elseif self.info then
      self:SetSize(self:GetWide(), 100 + SB_ROW_HEIGHT)
      self.info:SetVisible(true)
      self.info:SetPos(5, SB_ROW_HEIGHT + 5)
      self.info:SetSize(self:GetWide(), 100)
      self.info:PerformLayout()
      self:SetSize(self:GetWide(), SB_ROW_HEIGHT + self.info:GetTall())
   self.nick:SetPos(SB_ROW_HEIGHT + 10, (SB_ROW_HEIGHT - self.nick:GetTall()) / 2)
   self.voice:SetVisible(not self.open)
   self.voice:SetSize(16, 16)
   self.voice:DockMargin(4, 4, 4, 4)
   self.voice:Dock(RIGHT)
function PANEL:DoClick(x, y)
   self:SetOpen(not self.open)
function PANEL:SetOpen(o)
   if self.open then
      surface.PlaySound("ui/buttonclickrelease.wav")
      surface.PlaySound("ui/buttonclick.wav")
   self.open = o
   self:PerformLayout()
   self:GetParent():PerformLayout()
   sboard_panel:PerformLayout()
function PANEL:DoRightClick()
vgui.Register( "TTTScorePlayerRow", PANEL, "Button" )
Thanks,
Owen
Offline Neku
Re: Lua error
« Reply #6 on: January 04, 2014, 03:37:42 pm »
It doesn't work because namecolor.tttadmin is being called as string.
Offline ojbristow
    • Superclocked
Re: Lua error
« Reply #7 on: January 04, 2014, 03:39:38 pm »
Jesus, im an idiot, thanks for pointing it out.
Owen
Offline Neku
Re: Lua error
« Reply #8 on: January 04, 2014, 03:43:29 pm »
It happens to everyone at some point.  ;)
