Author Topic: !slaynr wont work! broken db?  (Read 11857 times)
Offline sabbath
« on: January 05, 2014, 01:25:22 pm »
When I use !slaynr on xgui or just chat command, it just says: x will not be slain next round.
What should I do?  Already restarted the server, reinstalled ulib, ulx and tttulx plugin, and nothing! Maybe is related to broken sv.db? Everything else work just fine.
Offline Neku
Re: !slaynr wont work! broken db?
« Reply #1 on: January 05, 2014, 01:29:09 pm »
This happens sometimes. It fixes itself for some reason though...
Not sure what to say besides use slay temporarily.
EDIT: Did anyone go full retard and do !slaynr ply 9999999999999999999999999999 ?
« Last Edit: January 05, 2014, 01:30:48 pm by Ven01273 »
Offline sabbath
« Reply #2 on: January 05, 2014, 01:40:58 pm »
Not that I know of... I could delete the sv.db but I would cause some chaos with my players because of the pointshop =/
Offline Neku
« Reply #3 on: January 05, 2014, 02:19:10 pm »
That won't solve very much. Just do !slay temporarily.
Offline sabbath
« Reply #4 on: January 05, 2014, 03:43:59 pm »
My post was moved to  News, what the ?! Im not responsible for this lol.
About my problem, Im trying to change the responsible table in the db to see if it sort it out
Offline Neku
« Reply #5 on: January 05, 2014, 04:04:13 pm »
Make sure to back up that file...
Wouldn't want to lose pointshop data.
« Reply #6 on: January 05, 2014, 04:10:53 pm »
I meant to move it to off topic.
Help and Support is meant for Team Ulysses projects (mainly Ulib/ULX)
slaynr is not a command written by our team.
Originally, the release that included slaynr would have been the best location, but, as we've locked it because it kept getting necroed even after the team that released it said it wouldn't be worked on anytime soon, off-topic was the next best location for this.
Sorry for the confusion of the multiple moves.
Offline bender180
    • Benders Villa
« Reply #7 on: January 07, 2014, 03:35:56 pm »
i had that issue when testing on listen servers but it never appeared on a dedicated issues cant be much more help other then that sorry maybe if you told me how to reproduce i could *TRY* and fix it...
Offline Neku
« Reply #8 on: January 07, 2014, 05:20:01 pm »
Like I said, maybe someone decided to do "!slaynr ply 9999999999999".
Offline bender180
    • Benders Villa
« Reply #9 on: January 08, 2014, 07:03:18 pm »
try removing the slays from that player if that isnt an option you will have to delete sv.db
Edit: I pushed a UNTESTED update to the github for the commands that should prevent this from happening
Edit 2: If an admin could be kind enough to link this thread in the commands original thread id appreciate it. (not asking for it to be unlocked, i just though i may have a quick prevention for this.)
« Last Edit: January 08, 2014, 07:13:16 pm by bender180 »
Offline Eccid
    • Terror Abound! Steam Group
« Reply #10 on: January 09, 2014, 10:59:02 am »
If you have access to webhosting, you may want to switch your pointshop over to mysql. It's saved me so much trouble since I switched. You should find more info about it on the main pointshop thread on facepunch, and you can use This to convert your sv.db so you don't lose anything.
