Author Topic: CenKik - Censoring and Kicking  (Read 55853 times)
Offline UnderYouFive
Re: CenKik - Censoring and Kicking
« Reply #45 on: August 17, 2014, 04:57:50 am »
Same, But I still really like it! But untill it's fixed. I found another chat system on the workshop but it does the same thing.
Offline Neku
« Reply #46 on: August 20, 2014, 10:59:03 am »
I'll be improving it, so hold on.
When you type in !shop and all that fun stuff, does it give any errors?
« Reply #47 on: August 21, 2014, 09:44:35 am »
Oh thank you very much! No I don't get anything.
« Last Edit: August 21, 2014, 02:09:41 pm by UnderYouFive »
Offline Neku
« Reply #48 on: August 28, 2014, 04:59:38 pm »
I made some improvements to the checks, but I haven't tested it at all.
Please try it out and leave feedback on this thread.
Offline ChaosWolf
« Reply #49 on: August 28, 2014, 11:22:13 pm »
I let my friend play with the lua, and uhm... well. his head is uhmm...
  1. --[[ END BASIC REGION. You should not proceed to edit beyond if you don't know what you're doing. You may risk breaking the script, or exploding your head. ]]--
  2.
  3. local function Riplash( ply, text )
  4.         local filter = text
  5.         kikpls = nil
  6.         CenKik.forcetext = nil
  7.         for k,v in pairs( CenKik.words ) do
  8.                 if string.find( string.lower( filter ), v, 1, true ) then
  9.                         if CenKik.censor then
  10.                                 filter = string.Explode( " ", filter )
  11.                                 for a,b in pairs( filter ) do
  12.                                         print( filter[k] )
  13.                                         if string.find( string.lower( filter[a] ), v, 1, true ) then
  14.                                                 local replace = string.rep( "*", string.len( v ) )
  15.                                                 filter[a] = string.gsub( string.lower( filter[a] ), v, replace )
  16.                                                 filter = string.Implode( " ", filter )
  17.                                                 kikpls = true
  18.                                         end
  19.                                 end
  20.                         end
  21.                 end
  22.         end
idk how to explain this to his fiancé...
Offline Neku
« Reply #50 on: August 28, 2014, 11:35:51 pm »
He should've heeded my warning.  ::)
« Reply #51 on: August 31, 2014, 03:38:17 am »
I got this error.
[ERROR] addons/cenkik/lua/autorun/server/meow.lua:27: <name> or '...' expected near '"Player"'
  1. unknown - addons/cenkik/lua/autorun/server/meow.lua:0
