Author Topic: Removing the ULX MOTD?  (Read 35922 times)
Offline xXBryanXx
« on: January 16, 2014, 04:31:37 pm »
I have a custom MOTD that I am trying to replace the default ULX MOTD with and I want to use the same command (!motd). When I disable the ULX motd, it disables the entire !motd command. I tried going into the ulx files and changing the ULX command to !umotd, but that didn't work. If anyone knows how to do this, please tell me. Thanks.
Re: Removing the ULX MOTD?
« Reply #1 on: January 16, 2014, 05:02:48 pm »
Put the motd you want under garrysmod_root/ulx_motd.txt.
Offline Neku
« Reply #2 on: January 16, 2014, 05:18:01 pm »
You mean a full on custom motd, or just one you wrote?
Offline xXBryanXx
« Reply #3 on: January 16, 2014, 05:49:44 pm »
It is a full on custom MOTD with derma panels etc.
« Reply #4 on: January 16, 2014, 08:14:27 pm »
Ah sorry, I misunderstood. You should be able to remove lua/ulx/modules/cl/motdmenu.lua to disable the ULX MOTD.
Offline xXBryanXx
« Reply #5 on: January 17, 2014, 12:59:45 pm »
I removed motdmenu.lua and it removes the ULX motd, but it seems like it's still interfering with my custom motd because nothing shows up now when I type !motd.
« Reply #6 on: January 17, 2014, 05:46:00 pm »
How did you register "!motd"?
Offline xXBryanXx
« Reply #7 on: January 18, 2014, 11:34:12 am »
What do you mean by that?
Offline Neku
« Reply #8 on: January 18, 2014, 11:45:05 am »
You need to add the command "!motd".
Offline xXBryanXx
« Reply #9 on: January 18, 2014, 12:31:27 pm »
To my custom MOTD? The command is already added to that.
« Reply #10 on: January 18, 2014, 03:17:28 pm »
How? Share the code.
Offline xXBryanXx
« Reply #11 on: January 18, 2014, 06:12:38 pm »
I purchased the MOTD from someone else. I have the code, but changing the command is in a config file which then links to another file which puts it into effect. I can show you the code for the config file, if that would be of any use.
It seems to me, that ulx still is trying to use the ULX motd, and doesn't let anything else use the !motd command.
« Reply #12 on: January 18, 2014, 10:15:07 pm »
No. It sounds like you're simply not registering it as a command.
Offline xXBryanXx
« Reply #13 on: January 19, 2014, 08:53:14 am »
I change the command to something else such as !motdu and it works. !motd does not work.
« Reply #14 on: January 20, 2014, 07:25:53 am »
The command is registered in ulx/modules/sh/menus.lua, but it's only registered if the motdmenu.lua exists.
