Author Topic: Interval in Adverts  (Read 22000 times)
Offline Fluffedwolf
Interval in Adverts
« on: January 18, 2014, 12:43:47 pm »
It would be much better if the intervals on the advertisements would be like ever so and so instead this message plays after so this message plays after so. It would be much more organized
Offline Neku
Re: Interval in Adverts
« Reply #1 on: January 18, 2014, 12:54:06 pm »
This is actually a great idea!
My adverts always seem to show over each other.
« Reply #2 on: January 18, 2014, 03:02:31 pm »
They can already be put into groups.
From the default adverts.txt
If you want to make it so that one advertisement is shown and then will always be followed by another,
; put them in a table. For example, if you add the following to the bottom of the file, A will always show
; first followed by B.
 "my_group"
; "text" "Advertisement A"
; "time" "200"
; "text" "Advertisement B"
; "time" "300"
I'm pretty sure XGUI allows for grouping.
Offline Fluffedwolf
« Reply #3 on: January 18, 2014, 03:41:59 pm »
As I said it should be so you say you want a message every 200 seconds then you place the interval 200 and each advert goes 200 after another. In ulx the max is 1000.
« Reply #4 on: January 18, 2014, 04:17:03 pm »
No, XGUI sets the highest number as 1000.
You can set up manually if you really want it higher, go to your gmod/data/ulx/adverts.txt and edit it.
XGUI does allow the way your asking already, just not as high as it seems you want.
Offline Storm
« Reply #5 on: January 18, 2014, 05:59:31 pm »
I have always had a problem with overlapping adverts. I always thought each was zero-based like 60 means every 60 seconds but do you mean the time represents the time after the last one?
« Reply #6 on: January 18, 2014, 09:55:23 pm »
ULX has two types - grouped and non-grouped.
Non grouped are zero based. Will show up at whatever time specified, individually.
Two adverts
Advert 1 at 60 seconds
advert 2 at 65 seconds
Second time, 1 will show up at 120, 2 will show up at 130
Grouped, 2nd add will always show up constant <x> after first>.
They're consecutive.
« Reply #7 on: January 18, 2014, 10:17:14 pm »
JamminR is right. Except, XGUI also allows you to input the value you want for the time rather than using the slider, so there's no need to go to the file to set it higher if that's what you want.
« Reply #8 on: January 18, 2014, 10:43:22 pm »
I thought we had BOTH input and sliders.
Text input boxes + lazy sliders FTW.
Offline sabo
  • Hello :)
    • The Elite Gaming
« Reply #9 on: January 19, 2014, 08:26:42 am »
Use the lua file in the attachments, put it to garrysmod/lua/autorun/...
This will basically print the adverts one by one, 1st then 2nd then 3rd then 4th ect...
The time between those adverts is configureable at the top.
This way it will never override a previous advert.
The script was made by a friend and given to me, the adverts are my own, feel free to keep/delete them to your liking.
Hope this helps.
« Reply #10 on: January 19, 2014, 09:44:31 am »
Sabo, why replace the functionality of ULX?
Offline Neku
« Reply #11 on: January 19, 2014, 01:18:57 pm »
Er... isn't lenny_ a hack?
« Reply #12 on: January 19, 2014, 01:20:33 pm »
The code is all legit, soooo... guess not.
Offline Neku
« Reply #13 on: January 19, 2014, 01:38:13 pm »
...Still not trusting that.
EDIT: Nevermind, I just took a look at the code. Seems clean.
Strange name to give a script though.
« Last Edit: January 19, 2014, 01:44:41 pm by Neku »
« Reply #14 on: January 19, 2014, 01:53:49 pm »
You- you don't trust me? D:
I took a look at the code before I said that. .-.
