Author Topic: Learning Lua... (Just a random post from a lua super noob.)  (Read 27855 times)
Offline syn.
  • Lua Padawan
    • SynGaming
Re: Learning Lua... (Just a random post from a lua super noob.)
« Reply #45 on: January 26, 2014, 03:15:42 pm »
I haven't added anything I've made myself to the server besided some really simple custom commands because TTT is confusing and I get stuck on where to put certain things and I don't really know much about gmod lua in general, also I can't seem to get ipairs :( I'll keep trying but any small hints on Jam's puzzle would be awesome:)
Lua Student
"The more you understand, the crazier you get."
« Reply #46 on: January 26, 2014, 03:31:24 pm »
ipairs = indexed pairs
k = (index) key
v = value
ipairs gives you both (a pair) from the table parts.
The for loop goes through the table and assigns each variable (k, v) the respective key and value.
Offline syn.
  • Lua Padawan
    • SynGaming
« Reply #47 on: January 26, 2014, 06:02:53 pm »
ohh okay so k would be the third key in the table (20) and value would be it's value?
If so then it would be: "I found 20!"
Lua Student
« Reply #48 on: January 26, 2014, 06:07:40 pm »
Partially correct. There's more output than that.
What would all the output be?
Offline syn.
  • Lua Padawan
    • SynGaming
« Reply #49 on: January 26, 2014, 06:19:15 pm »
  1. 1   0
  2. 2   100
  3. 3   20
  4. 4   99
  5. I found 20!
because you are printing all k, v's and then afterward you are printing I found 20!
Lua Student
« Reply #50 on: January 26, 2014, 08:14:05 pm »
Close.
The if statement is inside the for loop, before the for loop finishes.
It would look like;
    1   0
    2   100
    3   20
    I found 20!
    4   99
Now, a small lesson.
Placing that if statement outside the for loop would do nothing, wouldn't print anything.
For loops are 'local'. You can't use information/variables created within the actual 'for' statement unless you assign them to a variable outside the scope.
k would be nil outside. v would be nil. nil ~= 3, so nothing would be printed of the 'i found' line (and v would be nil too)
To make the code do the output like you originally said it would look like would be like this;
x = { 0, 100, 20, 99 }
for k, v in ipairs( x ) do --k/v = local, x is a global (to this anyway) table
   print ( k, v )
   if k == 3 and v == 20 then c = 20 end --k/v = local, c = global
   if c == 20 then print ( "I found " .. c .. "!") end
(Oh, and though the 'and' comparison in the k= and v= is totally unnecessary (you could use 'if v == 20', I threw it in to show some logic operators.)
Offline syn.
  • Lua Padawan
    • SynGaming
« Reply #51 on: January 27, 2014, 05:18:56 pm »
Ohh okay thanks jam I mostly get confused on what is called what, for example I had no idea k and v were keys and values (even though in hindsight it seems a bit obvious).
Lua Student
