Author Topic: Server crash on boot caused (possibly) by ULX..?  (Read 6449 times)
« on: January 29, 2014, 02:31:29 pm »
So i did some edits to users.txt and groups.txt earlier (yes, i know it's a bad idea...), and I rebooted my server to make the changes take effect...
...and my server just stopped booting.
After viewing my console log, I found nothing but a cutoff after a few of the ULX "I loaded myself and these modules" messages.
After I removed ULX and ULib as per request by my GSP, my server booted fine.
I have my ULX and ULib data files on a read-only anonymous FTP server with this login:
Hostname:ftp.ponypwnage.net
Username:anonymous@ponypwnage.net
If anyone cam check those files out for me, that would be nice. :)
If you guys need any other files, just tell me.
Re: Server crash on boot caused (possibly) by ULX..?
« Reply #1 on: January 29, 2014, 03:29:11 pm »
So many different quirks, any one could be causing issue, and should be obvious 'hmm, this doesn't look right' to you too.
For now, just a QUICK review of groups.txt.
I've not even started testing bracket/syntax yet.
uvip group -
unmapvote and mapvote - are those 3rd party ULX commands? If so, they're missing "ulx", ie "ulx unmapvote"
trusted-
bring,kick,slap,slay missing "ulx"
Line 154 -
" " group name.
Not sure that will work.
supervisor -
"ulx" "addgroup" - not proper format. "ulx addgroup"
superadmin -
"" "!tp" - not sure what you were trying, but that doesn't look right. Nul might give error on parse.
« Reply #2 on: January 29, 2014, 04:24:39 pm »
Yeah, those permission quirks were from other admins with groupallow. Everything worked fine before I changed the can_target and inheritance of co-owner and owner, plus moved a few permission lines from owner to co-owner...
EDIT: Also messed with the entry for |PP| Vinyl Scratch. Should be the first or second entry.
« Last Edit: January 30, 2014, 02:39:27 pm by Princess Twilight Sparkle »
« Reply #3 on: January 30, 2014, 02:40:38 pm »
*bump*
If it helps, i was using a mobile Subline-style FTP client/code editor called FTP Manager.
:p
« Reply #4 on: January 30, 2014, 03:24:59 pm »
One more thing- I'm kinda not up-to-date on both GMod and ULX/ULib, it that makes any difference...
I'm planning to update tomorrow- just been withholding due to the daunting process.
« Reply #5 on: January 31, 2014, 05:06:34 pm »
Double bump, because I have a new update.
I updated ULX and ULib to the SVN releases, and ran a GMod update via my GSP's CPanel, with no results.
So, does anyone have any help they can give..? I'm at a loss at this point...
« Reply #6 on: January 31, 2014, 07:47:27 pm »
One more thing-
This is the last few lines of my console.log...
The server crashes after ucl.lua loads...
//  shared/hook.lua          //
EDIT: I have modded a few files in ULX/ULib...
Here they are:
ULX:
motdmenu.lua
ULib (unconfirmed; will confirm tomorrow):
player.lua (for SBans integration)
« Last Edit: January 31, 2014, 09:34:09 pm by Princess Twilight Sparkle »
« Reply #7 on: February 01, 2014, 12:44:40 pm »
Fixed...
Apparently i had a group with a nil name... o-o
« Reply #8 on: February 01, 2014, 02:31:30 pm »
Fixed...
Line 154 -
" " group name.
Technically though, space is not nil.
