General
Developers Corner
Setting maps to fastdl when that map is chosen
Topic: Setting maps to fastdl when that map is chosen (Read 13442 times)
syn.
Jr. Member
Lua Padawan
January 30, 2014, 05:02:30 pm »
okay title might be weird but is there any way to set the maps to download only when it is selected and we are loading for that particular map? if there is please help me do it:o thanks
WOOOO JR MEMBER:D
Lua Student
"The more you understand, the crazier you get."
Eccid
Full Member
Hey, come on... We just met...
Re: Setting maps to fastdl when that map is chosen
January 30, 2014, 05:09:58 pm »
if your fastdl is set up right, gmod should automatically do that.
syn.
Jr. Member
Lua Padawan
Reply #2 on:
January 30, 2014, 05:24:03 pm »
what my FastDL does is that whenever a new player joins my server, it forces them to download ALL of the maps. This makes the loading time of my server skyrocket. I think it would be better for them to download each map whenever the have to PLAY that map.
Lua Student
Bytewave
Respected Community Member
Reply #3 on:
January 30, 2014, 05:26:01 pm »
FastDL hasn't ever done that to me...
You're on XenonServers, I think, right?
syn.
Jr. Member
Lua Padawan
Reply #4 on:
January 30, 2014, 05:28:11 pm »
yep maybe I have a different method of FastDl o.O I just added a workshop.lua on lua/autorun/server/ and manually added each file (resource.AddWorkshop("335286353") )
Lua Student
Neku
Reply #5 on:
January 30, 2014, 05:32:40 pm »
Yeah, you don't need to do that.
Just leave it alone. Maps automatically download.
syn.
Jr. Member
Lua Padawan
Reply #6 on:
January 30, 2014, 05:34:48 pm »
ohh so I dont add the wokrshop.lua? is that it?
Lua Student
Neku
Reply #7 on:
January 30, 2014, 07:18:04 pm »
Remove the ones for maps.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #8 on:
January 30, 2014, 07:20:17 pm »
The only time you add a workshop lua is if it's a workshop item for lua/models/sounds.
Maps by default, if on the fastdl host, will download when you're on that map.
Make sure to bz2 compress them. (Find any 'Source map bz2' tutorial)
Bytewave
Reply #9 on:
January 30, 2014, 07:29:30 pm »
You could technically do this, could you not?
--This is a list of your server's maps which are available through the workshop
--Each one uses the map file's name and the workshop ID
maplist
--change this table definition to your needs.
maplist
"ttt_community_bowling_v5a"
"131667838"
maplist
"ttt_westwood_v4"
"104520719"
maplist
"ttt_mc_skyislands"
"106498411"
local
map
game
GetMap
-- Get's the current map name
local
workshopid
maplist
map
-- Finds the workshop ID for the current map name from the table above
if
workshopid !
nil
then
--If the map is in the table above, add it through workshop
print
"[WORKSHOP] Setting up maps. "
map
" workshop ID: "
workshopid
resource
AddWorkshop
workshopid
--If not, ) then hope the server has FastDL or the client has the map
print
"[WORKSHOP] Not available for current map. Using FastDL instead hopefully..."
Taken from the GMod wiki.
Neku
Reply #10 on:
January 30, 2014, 07:35:04 pm »
That works, but is not needed.
Bytewave
Reply #11 on:
January 30, 2014, 07:39:46 pm »
Quote from: Neku on January 30, 2014, 07:35:04 pm
Well, Workshop is most likely faster than a conventional FadtDL server... I'm actually planning doing a Workshop DL system for my server to decrease total loading time.
JamminR
Ulysses Team Member
Reply #12 on:
January 31, 2014, 02:18:00 pm »
Here's the issue.
By uploading anything to workshop, you're agreeing that 1) you own/are the creator of the content being uploaded and therefore 2) You're allowing Valve to lay claim to it, if they so wish.
General
Developers Corner
