Author Topic: Help with modding Murder gamemode..  (Read 16053 times)
Offline Neku
Re: Help with modding Murder gamemode..
« Reply #15 on: February 03, 2014, 09:21:35 pm »
  1. local function IgniteBystander( victim, inflictor, attacker )
  2.
  3.         if not attacker:GetMurderer() and not victim:GetMurderer() then
  4.                 attacker:Ignite()
  5.         end
  6.
  7. end
  8. hook.Add("PlayerDeath", "BystanderPunishment", IgniteBystander)
  9.
That should work.
« Last Edit: February 03, 2014, 09:46:40 pm by Neku »
« Reply #16 on: February 03, 2014, 09:38:52 pm »
you forgot your parenthesis in your second GetMurderer()
Offline VonTreece
« Reply #17 on: February 03, 2014, 09:43:01 pm »
Alright, going to try using this code here:
function IgniteBystander(victim,inflictor,attacker)
attacker:Ignite(30)
Will post results!
Offline Neku
« Reply #18 on: February 03, 2014, 09:45:39 pm »
Haha, whoops!
Offline VonTreece
« Reply #19 on: February 03, 2014, 10:51:28 pm »
Works flawlessly! (No errors either!)
Thank you all for your help!
For anyone who's interested here's the code used:
attacker:Ignite(30)
Thanks again!
Offline Storm
« Reply #20 on: February 05, 2014, 03:35:11 am »
I am very interested I have the exact same problem! Is what you last posted the only thing that needs to be changed? Where in the files did you wind up putting the code? Does this actually kill the player? This will be great for Murder servers!
Offline Neku
« Reply #21 on: February 05, 2014, 11:12:57 pm »
If you want them to die, use something like:
  1. local function KillBystander( victim, inflictor, attacker )
  2.
  4.                 attacker:Kill() -- Watch RDMers suffer ;)
  5.         end
  6.
  7. end
  8. hook.Add("PlayerDeath", "BystanderPunishment", KillBystander)
Offline VonTreece
« Reply #22 on: February 06, 2014, 02:41:55 am »
Yep! All you need to do is save the code as a .lua (e.g. - ignitebystander.lua) and then add it directly in to "garrysmod/lua/autorun/server".
It will ignite and eventually kill any bystander who kills an innocent bystander.
If you'd like to instantly kill rather than ignite a player, refer to Neku's post above. ^
