Author Topic: Motd issue  (Read 4439 times)
Offline Tarado
Motd issue
« on: February 04, 2014, 07:35:51 am »
Hi,
I recently made my own MOTD on Photoshop and knowing that the motd is displayed by HTML removed the default MOTD codes and I simply replaced it with an IMG Tag with the source as the MOTD's JPEG file.
However, when I and other players join the server, we dont see the MOTD that I made but instead a grey background.
How can I fix this ?
I've tried changing the resolution of the Derma Panel on LUA to the same resolution as the JPEG file (which is 1280 x 720 ) but it does not fix the problem.
Offline Neku
Re: Motd issue
« Reply #1 on: February 04, 2014, 07:55:24 am »
Did you try resizing the image?
Offline Tarado
Re: Motd issue
« Reply #2 on: February 04, 2014, 08:35:05 am »
I want the image to be big enough because I have some small text on it.
Offline Neku
Re: Motd issue
« Reply #3 on: February 04, 2014, 09:54:47 am »
I've read somewhere that you need it to be small.
Re: Motd issue
« Reply #4 on: February 04, 2014, 03:29:33 pm »
Where are you hosting y our img?
What is now in your motd file?
Attach it or post it in bb code tag here.
Offline Tarado
Re: Motd issue
« Reply #5 on: February 05, 2014, 05:39:06 am »
I've fixed the problem. The resolution of the VGUI pane has to be slightly larger than the image itself.
