Author Topic: How to disable ulx motd from displaying for staff  (Read 14039 times)
Offline Storm
« on: February 05, 2014, 04:31:58 am »
Is there some code I can add to disable the motd from displaying and having to click "ok" for ulx groups (moderator, admin, etc)?
Offline Tarado
Re: How to disable ulx motd from displaying for staff
« Reply #1 on: February 05, 2014, 07:59:36 am »
Im sure you can add a "ply.CheckGroup" script to the lua file for the motd.
Not Tested, just theoretical .
local url
function StaffDisplay()
    if ply:CheckGroup("admin") then
        ply:ulx.motd_exists(false)
    elseif ply:CheckGroup("moderator") then
    elseif ply:CheckGroup("superadmin") then
« Last Edit: February 05, 2014, 09:15:53 am by Tarado »
Offline Storm
« Reply #2 on: February 06, 2014, 05:08:02 pm »
Thanks but this didnt seem to work. Does anyone else have any other ideas?
« Reply #3 on: February 06, 2014, 07:30:23 pm »
Comment out gmod/data/ulx/config.txt "motdfile", then make sure your script or server.cfg is setting the motdfile convar to something other than what it used to have for ULX.
If you've not reset it on the server, it's likely the same.
Offline Storm
« Reply #4 on: February 07, 2014, 04:55:53 am »
Thanks but how does this make it not display for just mods and admins?
« Reply #5 on: February 07, 2014, 09:21:19 pm »
Sorry, got your question mixed up with someone else trying to stop motd totally.
It was late. I was tired. I'll go find that thread and post my same answer there. :D
« Reply #6 on: February 09, 2014, 04:14:40 pm »
Before
`if showMotd == "1" then`
in menus.lua
add
`if ply:IsAdmin() then return end` (or whatever logic you need for the groups you're exempting)
Offline Storm
« Reply #7 on: February 10, 2014, 04:47:14 am »
Thanks so much! Does inheritance work with this? If I put moderator, will it work for all groups above?
« Reply #8 on: February 10, 2014, 06:41:35 am »
IsAdmin() will work for groups that inherit from the default "admin" group. If it's only moderator you're worried about (and there's no group between "moderator" and "admin" or "moderator" and "user") that you want to disable the MOTD for, you can do something like this:
if ply:IsAdmin() or ply:IsUserGroup( "moderator" ) then return end(This is just an edit from Megiddo's suggestion)
Offline Storm
« Reply #9 on: February 10, 2014, 09:36:09 am »
Thanks. This is what I now have in that file:
local function sendMotd( ply, showMotd )
if showMotd == "1" then -- Assume it's a file
if ply.ulxHasMotd then return end -- This player already has the motd
if not ULib.fileExists( GetConVarString( "motdfile" ) ) then return end -- Invalid
local f = ULib.fileRead( GetConVarString( "motdfile" ) )
For some reason this has no effect (the motd still comes up for all groups.) Can you tell me what I am doing wrong?
« Reply #10 on: February 10, 2014, 12:50:45 pm »
Try to move this:
if ply:IsAdmin() or ply:IsUserGroup( "moderator" ) then return endBelow this:
So your code pretty much looks like this:
Offline Storm
« Reply #11 on: February 10, 2014, 01:08:33 pm »
I tried this and double checked it and it still doesnt work.
« Reply #12 on: February 10, 2014, 03:15:02 pm »
Did you change maps after editing the file? Are you sure you edited the right file? Try adding print statements, if nothing else.
Offline Storm
« Reply #13 on: February 10, 2014, 04:23:42 pm »
I restarted the server twice and I double checked the file that was on the server after it didnt work. I edited the menus.lua file. The following is what is on the server.
local CATEGORY_NAME = "Menus"
if ULib.fileExists( "lua/ulx/modules/cl/motdmenu.lua" ) or ulx.motdmenu_exists then
CreateConVar( "motdfile", "ulx_motd.txt" ) -- Garry likes to add and remove this cvar a lot, so it's here just in case he removes it again.
ULib.clientRPC( ply, "ulx.rcvMotd", false, f )
ply.ulxHasMotd = true
else -- Assume URL
ULib.clientRPC( ply, "ulx.rcvMotd", true, showMotd )
ply.ulxHasMotd = nil
local function showMotd( ply )
local showMotd = GetConVarString( "ulx_showMotd" )
if showMotd == "0" then return end
if not ply:IsValid() then return end -- They left, doh!
ULib.clientRPC( ply, "ulx.showMotdMenu", ply:SteamID() ) -- Passing it because they may get it before LocalPlayer() is valid
hook.Add( "PlayerInitialSpawn", "showMotd", showMotd )
function ulx.motd( calling_ply )
if not calling_ply:IsValid() then
Msg( "You can't see the motd from the console.\n" )
return
if GetConVarString( "ulx_showMotd" ) == "0" then
ULib.tsay( ply, "The MOTD has been disabled on this server." )
return
showMotd( calling_ply )
local motdmenu = ulx.command( CATEGORY_NAME, "ulx motd", ulx.motd, "!motd" )
motdmenu:defaultAccess( ULib.ACCESS_ALL )
motdmenu:help( "Show the message of the day." )
if SERVER then ulx.convar( "showMotd", "1", " <0/1/(url)> - Shows the motd to clients on startup. Can specify URL here.", ULib.ACCESS_ADMIN ) end
« Last Edit: February 10, 2014, 04:28:52 pm by Storm »
« Reply #14 on: February 10, 2014, 05:19:54 pm »
Okay, I think I flubbed on remembering my own functions. ;)
Try putting `if ply:IsAdmin() or ply:IsUserGroup( "moderator" ) then return end` right after `local function showMotd( ply )`.
