Author Topic: Rank serious problem  (Read 3613 times)
Offline pathos
« on: February 12, 2014, 01:14:24 pm »
Okay so me being stupid, i downloaded it, and got it to work and stuff, i was messing with the groups, and i assigned myself to a lower rank. And now i cant use any of the stuff on the cmd's. I tried re installing it ( C:\Program Files\Steam\SteamApps\[MYNAME]\garrysmod\garrysmod\addons ) is where its at. Still no luck. is there a way to change this? I was at super admin now im something lower or something that has hardly any commands. or whatever. Help pleasseeee i really wanna use it. thanks,.
I assume maybe theres a !setrank but idk. im doing it wrong, if there is
Re: Rank serious problem
« Reply #1 on: February 12, 2014, 02:57:01 pm »
ULysses F.A.Q.s are your friends.
/index.php/board,30.0.html
You'd set your group higher the same way you should have set yourself in the first place... server console.
/index.php/topic,5766.0.html
If that fails, see the original 'trouble with access' FAQ.
/index.php/topic,383.0.html
If all else fails, reset ULib/ULX - a reinstall of the addons folder does no good...that's not where any addon data is stored, usually ever.
/index.php/topic,5765.0.html
Offline Neku
« Reply #2 on: February 12, 2014, 03:08:27 pm »
Your file path is probably wrong too.
steamapps/name has not been used for gmod in quite a while.
Since this is on your own client, you can just open console and type
ulx adduser ^ superadmin
If that doesn't work, switch ^ and superadmin around.
« Last Edit: February 12, 2014, 03:14:29 pm by Neku »
