Author Topic: Trying to learn lua a little  (Read 13452 times)
Offline Desimay
« on: February 12, 2014, 08:40:53 pm »
So I am trying to learn lua a little and I wrote this for my server.
function AddHpToLevel(ply)
if ( ply:getLevel() <= 60 ) then
ply:SetHealth(700)
if ( ply:getLevel() <= 50 ) then
ply:SetHealth(600)
if ( ply:getLevel() <= 40 ) then
ply:SetHealth(500)
if ( ply:getLevel() <= 30 ) then
ply:SetHealth(400)
if ( ply:getLevel() <= 20 ) then
ply:SetHealth(300)
if ( ply:getLevel() <= 10 ) then
ply:SetHealth(200)
hook.Add("PlayerSpawn", "test", AddHpToLevel)
But it doesn't seem to work. Is there something I am doing wrong?
Re: Trying to learn lua a little
« Reply #1 on: February 12, 2014, 08:59:09 pm »
Where do you have the file this code is in?
Tried adding print messages for debugging, both within the function, and outside of it (to see that it's even loading?)
Do you have a function called getLevel somewhere?
Offline Desimay
« Reply #2 on: February 12, 2014, 09:02:54 pm »
Ok it does run but doesn't set my HP. The getLevel is this function.
function meta:getLevel()
return self:getDarkRPVar('level')
Offline Neku
« Reply #3 on: February 12, 2014, 09:07:06 pm »
Okay...
Does getDarkRPVar exist?
Offline Desimay
« Reply #4 on: February 12, 2014, 09:11:12 pm »
Okay...
Yes, the level mod works fine.
Offline Neku
« Reply #5 on: February 12, 2014, 09:28:39 pm »
Perhaps you could try removing the quotes from
Offline Desimay
« Reply #6 on: February 12, 2014, 09:38:40 pm »
The level mod works fine, it is just that I want it to set a users health depending on what level, aka level 60 gets 600 health. I am running a Gang Wars RP so the more health the better
Offline Neku
« Reply #7 on: February 12, 2014, 10:07:32 pm »
How about instead of end...
Start using elseif, right now if you have it so any level below 60 gets 700 HP.
Offline Desimay
« Reply #8 on: February 13, 2014, 07:36:39 am »
Ok I did that but it is still not setting HP. It does run the script though.
if ( ply:getDarkRPVar('level') >= 60 ) then
ply:SetHealth(700)
elseif ( ply:getDarkRPVar('level') >= 50 ) then
ply:SetHealth(600)
elseif ( ply:getDarkRPVar('level') >= 40 ) then
ply:SetHealth(500)
elseif ( ply:getDarkRPVar('level') >= 30 ) then
ply:SetHealth(400)
elseif ( ply:getDarkRPVar('level') >= 20 ) then
ply:SetHealth(300)
elseif ( ply:getDarkRPVar('level') >= 10 ) then
ply:SetHealth(200)
print( "Loaded HP Gen2222");
I have tried that with no luck.
« Last Edit: February 13, 2014, 07:40:14 am by Desimay »
« Reply #9 on: February 13, 2014, 07:58:15 am »
1) As I originally asked, where are you putting this code?
It's possible, depending on where it is, that it's loading before the functions it uses are created by the gamemode or addon.
2) Try a print command inside the function too, to see if it's working right when it runs, if the hook is even running.
print ( ply:Nick() .. " level is ".. ply:getDarkRPVar('level') )
Offline Desimay
« Reply #10 on: February 13, 2014, 07:59:54 am »
I did some testing and I ran this on my dev server
lua_run_cl for k,v in pairs(player.GetAll() ) do local lvl = v:getDarkRPVar('level') print(lvl) end  and that seems to work. So getting the level is client side but I need to set the health.
« Reply #11 on: February 13, 2014, 08:02:17 am »
Does the darkrp level var or getlevel function exist on server?
Seems silly the info like that would be client only.
Offline Desimay
« Reply #12 on: February 13, 2014, 08:04:54 am »
The getDarkRPVar('level') is client side.
« Reply #13 on: February 13, 2014, 08:40:46 am »
Right, seeing 'self' in the actual function indicates that the function itself is client.
You'd need to find out if the DarkRP variable 'level' exists on the server side.
If it's on the server, a server side function could be written (if not already exist) to get the value for players on server side.
(return ply:getDarkRPVar('level') instead of self:)
EDIT: According to DarkRP WIKI - GetDarkRPVar is shared.
http://wiki.darkrp.com/index.php/Functions/player/shared/getdarkrpvar
You just need to make sure your code is running on server side only.
« Last Edit: February 13, 2014, 08:47:09 am by JamminR »
Offline Desimay
« Reply #14 on: February 13, 2014, 11:17:54 am »
Ok I think I found something that might work.
Client Side:
if ( SERVER ) then return; end
function PlayerCheck()
for k,v in pairs( player.GetAll() ) do
if ( v:getDarkRPVar('level') >= 70 ) then
net.Start("Send_HP_70")
net.SendToServer()
elseif ( v:getDarkRPVar('level') >= 60 ) then
net.Start("Send_HP_60")
net.SendToServer()
elseif ( v:getDarkRPVar('level') >= 50 ) then
net.Start("Send_HP_50")
net.SendToServer()
elseif ( v:getDarkRPVar('level') >= 40 ) then
net.Start("Send_HP_40")
net.SendToServer()
elseif ( v:getDarkRPVar('level') >= 30 ) then
net.Start("Send_HP_30")
net.SendToServer()
elseif ( v:getDarkRPVar('level') >= 20 ) then
net.Start("Send_HP_20")
net.SendToServer()
elseif ( v:getDarkRPVar('level') >= 10 ) then
net.Start("Send_HP_10")
net.SendToServer()
hook.Add( "PlayerSpawn", "PlayerCheck", PlayerCheck);
Server Side:
if ( CLIENT ) then return; end
util.AddNetworkString( "Send_HP_70" );
util.AddNetworkString( "Send_HP_60" );
util.AddNetworkString( "Send_HP_50" );
util.AddNetworkString( "Send_HP_40" );
util.AddNetworkString( "Send_HP_20" );
util.AddNetworkString( "Send_HP_10" );
net.Receive( "Send_HP_70", function(ply)
ply:SetHealth(700);
end )
net.Receive( "Send_HP_60", function(ply)
ply:SetHealth(700);
end )
net.Receive( "Send_HP_50", function(ply)
ply:SetHealth(700);
end )
net.Receive( "Send_HP_40", function(ply)
ply:SetHealth(700);
end )
net.Receive( "Send_HP_30", function(ply)
ply:SetHealth(700);
end )
net.Receive( "Send_HP_20", function(ply)
ply:SetHealth(700);
end )
net.Receive( "Send_HP_10", function(ply)
ply:SetHealth(700);
end )
