ULX MOTD text blacked out
Topic: ULX MOTD text blacked out (Read 6086 times)
joshh20
February 16, 2014, 01:41:14 pm »
Hello, I am experiencing a text rendering issue I believe, however, I am unsure as to the proper way to fix it. All of the text in my MOTD is bordered by black blocks which make the black text impossible to read and the rest of it quite ugly. I was wondering if anyone knew of a solution to this problem if you have encountered it before. Thank you -Josh
Here is a screenshot showing what I mean:
http://gyazo.com/1edcc935a418293811eaac84a8ff41ba
Neku
Re: ULX MOTD text blacked out
February 16, 2014, 01:42:17 pm »
Restart your game.
If that doesn't work, change the font.
joshh20
Reply #2 on:
February 16, 2014, 01:59:18 pm »
Thank you for the reply, but multiple users have seen this issue and I have tried switching the font to no avail.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #3 on:
February 16, 2014, 02:35:26 pm »
Please attach your motd here.
Not sure what you're doing, but some formatting of the text/font in your HTML is likely causing the issue.
joshh20
Reply #4 on:
February 16, 2014, 03:39:18 pm »
I would post the entire thing, but is rather long, so instead you can view it at my website, just view source.
http://jcraft.us/rules
JamminR
Ulysses Team Member
Reply #5 on:
February 16, 2014, 03:51:21 pm »
For starters, just try testing NOT using any font style.
Helvetica, I think, is a Microsoft font, and I think Gmod html engine only has some basic fonts.
joshh20
Reply #6 on:
February 16, 2014, 04:15:47 pm »
Ok, I have changed that at this time, however I was getting the same issue even when I had not specified a font. I changed it now because Neku had recommended it.
joshh20
Reply #7 on:
February 18, 2014, 02:03:13 pm »
Would you have further recommendations to fix this issue?
Megiddo
Ulysses Team Member
Project Lead
Reply #8 on:
February 18, 2014, 05:08:49 pm »
Strip it down to plain text and add each change to it incrementally to see what breaks it.
joshh20
Reply #9 on:
February 23, 2014, 02:15:12 pm »
Ok, I changed the background color to RosyBrown, and that seems to have fixed it, thank you guys for helping.
If anyone else encounters this issue, try this code in your HTML
Code:
[Select]
<body bgcolor="RosyBrown"></body>
