Author Topic: Having Admin Menu Touble  (Read 4678 times)
Offline Warrigel
« on: February 08, 2007, 06:44:14 pm »
Hey, I've just got a problem with my admin menu. I press the key I binded to ulx menu, it didn't work like it usually works. So, I tried every other command to get it to work..and still nothing. Evidently it works for the clients I have connected, they can get the menu to come up, but luckily they still can't use it. Just for some reason it won't come up for me. Any suggestions would be welcomed.
Re: Having Admin Menu Touble
« Reply #1 on: February 08, 2007, 07:34:04 pm »
Do any errors appear, either in your game console, and your server console if its dedicated?
Are you sure the bound key hasn't been changed/erased.
Type 'bind <yourkey>" in console. If it says "is not bound", something changed.
Rebind it.
If you get a different error, please tell us what it is.
Can you type "ulx who" in console and verify you are listed as admin?
Can you type "ulx menu" in your console, then go back to game screen and see the menu?
Did you install any mods/addons/other lua scripts at about/around the same time this started happening?
More info please.
Also, See http://www.ulyssesmod.net/bugs/view_all_bug_page.php , our bug tracker. If none of the questions above provide us with a helpful answer, you may be experiencing one of two or three bugs listed there. Possibly you are experiencing bug #20 or Bug #47
