Author Topic: Restrictions aren't working  (Read 3593 times)
Offline Shadotak
« on: February 20, 2014, 08:53:31 pm »
I just posted a topic related to this - my Minge group. They aren't supposed to have access to anything. They inherit rights from Users, which have several commands such as teleport, goto, and god.
At first, I took Gower's and Stickly Man!'s advice to use ulx denyaccess to remove the inherited commands, but I got an error saying Minge didn't have access to it. Then, I tried setting it so Minge can't target anyone, and that didn't work. I tried the following:
1. !*
2. !%minge,!%user,!%regular,!%expert,!%respected,!%admin,!%superadmin,!%owner
3. Restricting each individual command with #2
4. !%user
None of these worked, and the Minge class was still able to use god, noclip, teleport, etc.
Where did I <censor> up? What's the best way to do this?
Also, Users can target !%user,^
EDIT: the Minge group also doesn't have the faded checked boxes like it normally would. The boxes are totally unchecked, even though Users have access to it and Minge inherits that access.
« Last Edit: February 20, 2014, 08:58:07 pm by Shadotak »
Re: Restrictions aren't working
« Reply #1 on: February 21, 2014, 02:02:20 pm »
Please attach the file from your server that gets created when you run "ulx debuginfo" on your server console. Console will tell you where it gets placed.
Without knowing exactly how you typed commands, for denyaccess, it's difficult to tell what you did wrong in that respect.
As for the other attempts, well, you only fired a shotgun, and it's difficult to tell what all is torn up now.
