Author Topic: ulx module/ulx help  (Read 17910 times)
Offline lampman13
Re: ulx module/ulx help
« Reply #15 on: February 25, 2014, 12:24:23 pm »
i thought it was in the developers corner and i know that it does but i only have one comma and it i suppoesed to be there but i even tryed to remove the comma so i could test it and it didnt work but i got it to work on client but not on a server for some reason and it is in addon format
Offline lynx
« Reply #16 on: February 25, 2014, 01:03:26 pm »
Remove the string concatinator (..) after the comma, and GetText is a function value so it needs to have (). So:
chat.AddText( Color( 0, 255, 0 ), "(ADMIN)", Color( 0, 255, 0 ), ..TextEntry:GetText )
Should be:
chat.AddText( Color( 0, 255, 0 ), "(ADMIN)", Color( 0, 255, 0 ), TextEntry:GetText() )
Offline lampman13
« Reply #17 on: February 25, 2014, 01:24:15 pm »
yeah i have that right now but it only works client side lol i did this last night i forgot i already had a thread and now i have a new one
but when i put it in a server it doesnt work can anyone help me with making it a ulx ! command and a "ulx    " command?
Offline lynx
« Reply #18 on: February 25, 2014, 01:38:26 pm »
Derma (textentry, etc) is all clientside. As is chat.AddText. If you want it to be distributed to clients, you need to either set up a net message (suggested) or a usermessage.
Net messages:
http://wiki.garrysmod.com/page/Net_Library_Usage
Send the text to the server (net.SendToServer) then process it to the clients you want (RecipientFilter) then send it back to the clients using a second net message, which the receive function would then process using chat.AddText
Offline lampman13
« Reply #19 on: February 25, 2014, 01:59:40 pm »
so my whole code wont work?
Offline lynx
« Reply #20 on: February 25, 2014, 02:31:06 pm »
It will, you just need to modify it to allow for talk between the client and the server.
Offline Cobalt
« Reply #21 on: February 25, 2014, 02:50:52 pm »
You can also use something such as ULib.tsay.
Offline lampman13
« Reply #22 on: February 25, 2014, 07:07:12 pm »
ok and how do i use ulib.tsay like
  1. Ulib.tsay(Color(255, 255, 255) "<MESSAGE GOES HERE>")
Offline Neku
« Reply #23 on: February 25, 2014, 07:09:53 pm »
Isn't there a wiki full of ULX/ULib functions documented?
I'd look there for functions if I were you.
Offline lampman13
« Reply #24 on: February 25, 2014, 07:12:27 pm »
yeah but i dont really like the ulib wiki as it does not explain well it gives you pretty much Ulib.tsay and thats it not how to use it
Offline Cobalt
« Reply #25 on: February 26, 2014, 11:22:22 am »
ULib.tsayColor( nil, false, colorarg, text [, ...] )
Offline lampman13
« Reply #26 on: February 26, 2014, 01:51:34 pm »
Great but it still doesnt work on a server :/ i did the tsay thing but it doesnt work anything else i have to change (just remember im still new)
  1. function UCast( ply )
  2.
  3.         local ply = LocalPlayer()
  4.
  5.         local BackGround = vgui.Create( "DFrame" )
  6.         BackGround:SetSize( 200,70 )
  7.         BackGround:SetPos( (ScrW()/2)-BackGround:GetWide(),(ScrH()/2)-BackGround:GetTall() )
  8.         BackGround:SetTitle( "UCast" )
  9.         BackGround:SetVisible( true )
  10.         BackGround:SetDraggable( true )
  11.         BackGround:ShowCloseButton( true )
  12.         BackGround:MakePopup()
  13.         BackGround.Paint = function()
  14.                 draw.RoundedBox(4, 0, 0, BackGround:GetWide(), BackGround:GetTall(), Color(0, 225, 225, 255))
  15.                 draw.RoundedBox(2, 2, 2, BackGround:GetWide()-4, 21, Color(255, 150, 0, 255))
  16.         end
  17.
  18.         local TextEntry = vgui.Create( "DTextEntry", BackGround )
  19.         TextEntry:SetPos( 20,30 )
  20.         TextEntry:SetTall( 20 )
  21.         TextEntry:SetWide( 160 )
  22.         TextEntry:SetEnterAllowed( true )
  23.         TextEntry.OnEnter = function()
  24.                 ULib.tsayColor( nil, false, Color(0, 0, 0), "(", Color(255, 0, 0), "ADMIN MESSAGE", Color(0, 0, 0), ")", Color(0, 255, 0), TextEntry:GetText() )
  25.                 BackGround:SetVisible()
  26.         end
  27. end
  28. concommand.Add("ucast_menu",UCast)
  29.
« Last Edit: February 26, 2014, 02:00:56 pm by lampman13 »
« Reply #27 on: February 26, 2014, 02:10:49 pm »
It will never work on server way you are trying.
THIS vvvvvvvv
Net messages:
Logic would be like.
if server then
    concommand to send <your message> using <umsg or net message or whatever server to client Gmod code exists>
    function containing all your gui setup, including variable that holds 'text' you passed from server that was passed to below hook.
    <net or umsg or whatever client listening> hook to listen for your named <net/umsg/whatever> that runs function
Offline lampman13
« Reply #28 on: February 26, 2014, 02:17:37 pm »
ok so JamminR you say my code just wont work on a server just not possible the ways its coded?
Offline Neku
« Reply #29 on: February 26, 2014, 03:15:29 pm »
Your code won't work because the server and client are two different things.
You need to send a message from the server to the client, telling them to do this.
