Author Topic: Murder ULX commands  (Read 42394 times)
Offline Boxama
Murder ULX commands
« on: February 23, 2014, 10:20:55 am »
I made a few ULX commands for use specifically with the Murder gamemode.
It includes several that I thought useful for my community's server:
  • !slaynr target [rounds] - Sets the target to be slain at the beginning of the next round. Prevents them from becoming the Murderer if they have any slays, meaning that rounds will not be cut short. Rounds do not stack, you must specify the amount you want if you wish to add more - default is a single round. If the player leaves with active autoslays it will automatically ban them (if you allow the setting). You can apply cumulative bans, which decides whether or not the players ban time should be multiplied by the number of autoslays they are attempting to evade. You can also specify exactly how many minutes the ban should last for, other settings can be changed in the file.
  • !unslaynr target - Removes all autoslays against the target.
  • !givemagnum target - Gives the target the magnum (cannot be given to the Murderer).
  • !respawn target - Pretty obvious; respawns the target. I've disabled respawning spectators for now to prevent gamemode errors.
  • !mapnr map - Sets the map to be changed to the map you specify at the beginning of the next round. Does not trigger autoslays at the beginning of the round. Warns players about the map change both when the command is run and at the end of the round.
  • !unmapnr - Removes the current map change, if there is one.
  • !forcemurderer target - The equivalent to setting someone as the Murderer in the scoreboard, but in command form so you can allow admins to use it without them being a server admin.
The commands should appear under the section named "Murder" in the xgui by default. You can change the name of the category in the config inside the file.
You can download the addon at my GitHub repository or from the attached zip file.
Installation is as simple as any other addon - drag and drop into the addons folder.
I hope some of you find this useful.
« Last Edit: February 25, 2014, 11:23:54 am by Boxama »
Offline pants
Re: Murder ULX commands
« Reply #1 on: February 23, 2014, 12:10:18 pm »
woah, dude, is there anyway I could get the slaynr that bans on leave working with TTT? that would be awesome.
Offline Cobalt
« Reply #2 on: February 23, 2014, 03:02:07 pm »
hook.Add( "PlayerDisconnected", "BanOnLeave", function( ply )
if ply:GetPData( "whatever the value is" ) then
--ban
end )
« Last Edit: February 24, 2014, 08:39:03 pm by Cobalt »
Offline Boxama
« Reply #3 on: February 25, 2014, 09:25:57 am »
if SERVER then
local banmins = 200
local culumativeban = true
hook.Add( "PlayerDisconnected", "BanThemSlayEvaders", function( ply )
local slays = tonumber( ply:GetPData( "slaynr_slays" ) ) or 0
if slays > 0 then
local reason, mins = "Attempting to evade "..slays.." autoslays.", ( culumativeban and slays*banmins or banmins )
ULib.kickban( ply, mins, reason )
ulx.fancyLogAdmin( nil, false, "Automatically banned #T for #i minutes (#s) ", ply, mins, reason )
end )
Drop this at the bottom of addons/Trouble In Terrorist Town ULX Commands/lua/ulx/modules/sh/ttt_admin.lua
Assuming you're using Bender180's ULX TTT commands.
« Last Edit: February 26, 2014, 08:13:40 am by Boxama »
Offline pants
« Reply #4 on: February 25, 2014, 07:40:52 pm »
Sweet thanks, that worked almost perfect! console just randomly spurts out this error
[ERROR] addons/ulx/lua/ulx/modules/sh/ttt_admin.lua:14: '=' expected near 'local'
  1. unknown - addons/ulx/lua/ulx/modules/sh/ttt_admin.lua:0
Line 14&15
local CATEGORY_NAME  = "TTT Admin"
local gamemode_error = "The current gamemode is not trouble in terrorest town"
any ideas on why it'd do that?
Offline Boxama
« Reply #5 on: February 26, 2014, 08:46:53 am »
Are you sure you put it at the end of the file? It works perfectly when I try it myself.
Offline pants
« Reply #6 on: February 26, 2014, 01:49:13 pm »
Yeah I put it at the very end
It works just fine too just randomly spits out that = sign lua error notifications. It isn't too big of a deal just obnoxious haha
I had to delete some of the code to make it fit in the post
a--[=[-------------------------------------------------------------------------------------------
?                              Trouble in Terrorist Town Commands                              ?
?                                   By: Skillz and Bender180                                   ?
?                  All code included is completely original or extracted                       ?
?            from the base ttt files that are provided with the ttt gamemode.                  ?
--[Ulx Completes]------------------------------------------------------------------------------
ulx.target_role = {}
function updateRoles()
table.Empty( ulx.target_role )
    table.insert(ulx.target_role,"traitor")
    table.insert(ulx.target_role,"detective")
    table.insert(ulx.target_role,"innocent")
hook.Add( ULib.HOOK_UCLCHANGED, "ULXRoleNamesUpdate", updateRoles )
updateRoles()
--[End]----------------------------------------------------------------------------------------
--[Global Helper Functions][Used by more than one command.]------------------------------------
--[[send_messages][Sends messages to player(s)]
@param  {[PlayerObject]} v       [The player(s) to send the message to.]
@param  {[String]}       message [The message that will be sent.]
function send_messages(v, message)
if type(v) == "Players" then
v:ChatPrint(message)
elseif type(v) == "table" then
for i=1, #v do
v[i]:ChatPrint(message)
--[[corpse_find][Finds the corpse of a given player.]
@param  {[PlayerObject]} v       [The player that to find the corpse for.]
function corpse_find(v)
for _, ent in pairs( ents.FindByClass( "prop_ragdoll" )) do
if ent.uqid == v:UniqueID() and IsValid(ent) then
return ent or false
--[[corpse_remove][removes the corpse given.]
@param  {[Ragdoll]} corpse [The corpse to be removed.]
function corpse_remove(corpse)
CORPSE.SetFound(corpse, false)
if string.find(corpse:GetModel(), "zm_", 6, true) then
corpse:Remove()
elseif corpse.player_ragdoll then
corpse:Remove()
--[[corpse_identify][identifies the given corpse.]
@param  {[Ragdoll]} corpse [The corpse to be identified.]
function corpse_identify(corpse)
if corpse then
local ply = player.GetByUniqueID(corpse.uqid)
ply:SetNWBool("body_found", true)
CORPSE.SetFound(corpse, true)
--[Force role]---------------------------------------------------------------------------------
--[[ulx.force][Forces <target(s)> to become a specified role.]
@param  {[PlayerObject]} calling_ply   [The player who used the command.]
@param  {[PlayerObject]} target_plys   [The player(s) who will have the effects of the command applied to them.]
@param  {[Number]}       target_role   [The role that target player(s) will have there role set to.]
@param  {[Boolean]}      should_silent [Hidden, determines weather the output will be silent or not.]
function ulx.slaynr( calling_ply, target_ply, num_slay, should_slaynr )
if not GetConVarString("gamemode") == "terrortown" then ULib.tsayError( calling_ply, gamemode_error, true ) else
local affected_plys = {}
local slays_left = tonumber(target_ply:GetPData("slaynr_slays")) or 0
local current_slay
local new_slay
if ulx.getExclusive( target_ply, calling_ply ) then
ULib.tsayError( calling_ply, ulx.getExclusive( target_ply, calling_ply ), true )
elseif num_slay < 0 then
ULib.tsayError( calling_ply, "Invalid integer:\"" .. num_slay .. "\" specified.", true )
current_slay = tonumber(target_ply:GetPData("slaynr_slays")) or 0
if not should_slaynr then
                new_slay = current_slay + num_slay
                new_slay = current_slay - num_slay
            --local slay_reason = reason
            --if slay_reason == "reason" then
            -- slay_reason = false
            --end
if new_slay > 0 then
                target_ply:SetPData("slaynr_slays", new_slay)
                --target_ply:SetPData("slaynr_reason", slay_reason)
target_ply:RemovePData("slaynr_slays")
                --target_ply:RemovePData("slaynr_reason")
local slays_removed = ( current_slay - slays_left ) or 0
if slays_removed==0 then
chat_message = ("#T will not be slain next round.")
elseif slays_removed > 0 then
chat_message = ("#A removed ".. slays_removed .." round(s) of slaying from #T.")
elseif slays_left == 1 then
chat_message = ("#A will slay #T next round.")
elseif slays_left > 1 then
chat_message = ("#A will slay #T for the next ".. tostring(slays_left) .." rounds.")
ulx.fancyLogAdmin( calling_ply, chat_message, target_ply, reason )
local slaynr = ulx.command( CATEGORY_NAME, "ulx slaynr", ulx.slaynr, "!slaynr" )
slaynr:addParam{ type=ULib.cmds.PlayerArg }
slaynr:addParam{ type=ULib.cmds.NumArg, default=1, hint="rounds", ULib.cmds.optional, ULib.cmds.round }
--slaynr:addParam{ type=ULib.cmds.StringArg, hint="reason",  ULib.cmds.optional}
slaynr:addParam{ type=ULib.cmds.BoolArg, invisible=true }
slaynr:defaultAccess( ULib.ACCESS_ADMIN )
slaynr:help( "Slays target(s) for a number of rounds" )
slaynr:setOpposite( "ulx rslaynr", {_, _, _, true}, "!rslaynr" )
--[Helper Functions]---------------------------------------------------------------------------
hook.Add("TTTBeginRound", "SlayPlayersNextRound", function()
for _,v in pairs(player.GetAll()) do
local slays_left = tonumber(v:GetPData("slaynr_slays")) or 0
if v:Alive() and slays_left > 0 then
local slays_left=slays_left -1
if slays_left == 0 then
                v:RemovePData("slaynr_slays")
                v:RemovePData("slaynr_reason")
                v:SetPData("slaynr_slays", slays_left)
v:Kill()
table.insert( affected_plys, v )
local corpse = corpse_find(v)
if corpse then
local slay_message
for i=1, #affected_plys do
local v = affected_plys[ i ]
local string_inbetween
if i > 1 and #affected_plys == i then
string_inbetween=" and "
elseif i > 1 then
string_inbetween=", "
string_inbetween = string_inbetween or ""
slay_message = ( ( slay_message or "") .. string_inbetween )
slay_message = ( ( slay_message or "") .. v:Nick() )
local slay_message_context
if #affected_plys == 1 then slay_message_context ="was" else slay_message_context ="were" end
if #affected_plys ~= 0 then
ULib.tsay(_, slay_message .. " ".. slay_message_context .." slain.")
end)
hook.Add("PlayerSpawn", "Inform" , function(ply)
local slays_left = tonumber(ply:GetPData("slaynr_slays")) or 0
local slay_reason = false
if ply:Alive() and slays_left > 0 then
local chat_message = ""
if slays_left > 0 then
chat_message = (chat_message .. "You will be slain this round.")
chat_message = (chat_message .. " and ".. (slays_left - 1) .." round(s) after the current round")
if slay_reason then
chat_message = (chat_message .. " for \"".. slays_reason .."\".")
chat_message = (chat_message .. ".")
ply:ChatPrint(chat_message)
end)
------------------------------ Next Round  ------------------------------
ulx.next_round = {}
local function updateNextround()
table.Empty( ulx.next_round ) -- Don't reassign so we don't lose our refs
    table.insert(ulx.next_round,"traitor") -- Add "traitor" to the table.
    table.insert(ulx.next_round,"detective") -- Add "detective" to the table.
    table.insert(ulx.next_round,"unmark") -- Add "unmark" to the table.
hook.Add( ULib.HOOK_UCLCHANGED, "ULXNextRoundUpdate", updateNextround )
updateNextround() -- Init
local PlysMarkedForTraitor = {}
local PlysMarkedForDetective = {}
function ulx.nextround( calling_ply, target_plys, next_round )
local unaffected_plys = {}
    for i=1, #target_plys do
        local v = target_plys[ i ]
        local ID = v:UniqueID()
        if next_round == "traitor" then
            if PlysMarkedForTraitor[ID] == true or PlysMarkedForDetective[ID] == true then
                ULib.tsayError( calling_ply, "that player is already marked for the next round", true )
                PlysMarkedForTraitor[ID] = true
        if next_round == "detective" then
                ULib.tsayError( calling_ply, "that player is already marked for the next round!", true )
                PlysMarkedForDetective[ID] = true
        if next_round == "unmark" then
            if PlysMarkedForTraitor[ID] == true then
                PlysMarkedForTraitor[ID] = false
            if PlysMarkedForDetective[ID] == true then
                PlysMarkedForDetective[ID] = false
        ulx.fancyLogAdmin( calling_ply, true, "#A has unmarked #T ", affected_plys )
        ulx.fancyLogAdmin( calling_ply, true, "#A marked #T to be #s next round.", affected_plys, next_round )
local nxtr= ulx.command( CATEGORY_NAME, "ulx forcenr", ulx.nextround, "!nr" )
nxtr:addParam{ type=ULib.cmds.PlayersArg }
nxtr:addParam{ type=ULib.cmds.StringArg, completes=ulx.next_round, hint="Next Round", error="invalid role \"%s\" specified", ULib.cmds.restrictToCompletes }
nxtr:defaultAccess( ULib.ACCESS_SUPERADMIN )
nxtr:help( "Forces the target to be a detective/traitor in the following round." )
local function TraitorMarkedPlayers()
for k, v in pairs(PlysMarkedForTraitor) do
if v then
ply = player.GetByUniqueID(k)
ply:SetRole(ROLE_TRAITOR)
            ply:AddCredits(GetConVarNumber("ttt_credits_starting"))
ply:ChatPrint("You have been made a traitor by an admin this round.")
PlysMarkedForTraitor[k] = false
hook.Add("TTTBeginRound", "Admin_Round_Traitor", TraitorMarkedPlayers)
local function DetectiveMarkedPlayers()
for k, v in pairs(PlysMarkedForDetective) do
if v then
ply:SetRole(ROLE_DETECTIVE)
            ply:Give("weapon_ttt_wtester")
ply:ChatPrint("You have been made a detective by an admin this round.")
PlysMarkedForDetective[k] = false
hook.Add("TTTBeginRound", "Admin_Round_Detective", DetectiveMarkedPlayers)
if SERVER then
local banmins = 2440
if slays > 0 then
end )
Offline bender180
    • Benders Villa
« Reply #7 on: February 26, 2014, 04:36:47 pm »
remove the a at the very start of the file before the commented block starts and it should fix it
Offline pants
« Reply #8 on: February 26, 2014, 09:25:24 pm »
oh wow, derp lol
Offline nogger
« Reply #9 on: April 11, 2014, 12:59:55 am »
if SERVER then
local banmins = 200
if slays > 0 then
end )
Is there a way i can make this only if the disconnect reason is Disconnected by user?
Because what if they get that silly timed out error, or steam auth ticket has been canceled
« Reply #10 on: April 11, 2014, 05:22:38 pm »
Nogger, I'm not sure if the PlayerDisconnected hook is comprehensive enough to determine how a player disconnected.
Offline Cobalt
« Reply #11 on: April 11, 2014, 06:29:19 pm »
You have to use gameevents for that.
gameevent.Listen( "player_disconnect" )
hook.Add( "player_disconnect", "asdf", function( data )
   local reason = data.reason
   print( reason ) --> "player timed out" or something
end )
« Reply #12 on: April 11, 2014, 08:09:42 pm »
I didn't know you could do that. Good to know.
Offline Cobalt
« Reply #13 on: April 13, 2014, 02:49:17 pm »
rofl
Offline Neku
« Reply #14 on: April 13, 2014, 04:08:53 pm »
rofl
Was it the exact same commands?
