General
Developers Corner
end map dilemma
Topic: end map dilemma (Read 4783 times)
talmera
end map dilemma
February 26, 2014, 08:58:11 pm »
Hi, I've been coding a cross server experience system for my community and I have it mostly ready for public testing but I'm having trouble figuring out how to get it to save the exp when the map is getting changed I have it saving fine on player disconnect.
I was wondering what would be the best approach to do this?
It's not a sin if it can't make me cry
He's not the devil unless there's fire in his eyes
It ain't the ghost if it don't speak in tongue
It's not a victory 'till the battles been won
Eccid
Full Member
Hey, come on... We just met...
Re: end map dilemma
February 26, 2014, 09:06:24 pm »
Try using the
Shutdown Hook
and making it save then.
talmera
Re: end map dilemma
Reply #2 on:
February 26, 2014, 09:15:30 pm »
oh cool I completely missed that hook when looking for a solution XD thanks I'll give it a go.
talmera
Re: end map dilemma
Reply #3 on:
February 27, 2014, 03:30:11 am »
Hmmm so I set up this function for use on the Shutdown hook you suggested but it's not called on map change like I was hoping?
function
saveAll
for
k
v
in
pairs
player
GetAll
do
local
PlyFormat
string
Replace
v
SteamID
local
PlySteam
v
SteamID
local
saver
Database
query
"UPDATE exp_storage SET `exp_total`='"
tec_PlyExp
PlySteam
"' WHERE `steam_id`='"
PlyFormat
saver
onSuccess
function
print
"[TGEXP] User saved to database"
saver
onError
function
print
"[TGEXP] save failed on leave"
saver
start
hook
Add
"ShutDown"
"savingAll"
saveAll
*Notes*
I am using the MySQLoo "addon" to update a database with the new values a player has for exp and I'm attempting to save all players on map change/server shutdown.
*Update*
after some tinkering it appears to be working now.
Last Edit: February 27, 2014, 07:50:45 am by talmera
Megiddo
Ulysses Team Member
Project Lead
Re: end map dilemma
Reply #4 on:
March 01, 2014, 02:44:14 pm »
Gmod crashes a lot, I'd recommend saving in intervals you're comfortable losing. E.g., if you only want to lose up to 30 seconds of data, save every 30 seconds.
General
Developers Corner
end map dilemma
