Update: So the full warning text now appears
(i.e. I type "!warn syst3M4TiK test warn" it displays
[Super Admin] [AWarn] You have been warned by syst3M4TiK for test warn."
instead of
[Super Admin] [AWarn] You have been warned by syst3M4TiK for test."
BUT
The server will not kick/ban me or any other player when I reach the threshold. I've tested it on myself and other players who were willing to be guinea pigs.
All options are checked, but they act as if the ConVars have been set to 0.
If I click a checkmark, it displays "
[AWarn] Value
(awarn_kick) has been set to
(0)" and the option STAYS checked.
Also to note: The Ban Time and Decay Rate values are not correct.
I have had multiple Superadmins attempt to change these through the GUI and none have succeeded, we all face the same problem.
Would clearing the warns database fix this problem? Are there console commands that I can run to change the ConVars?
Also, my current server.cfg setup with the awarn options:
//AWARN
awarn_kick 1
awarn_kick_threshold 3
awarn_ban 1
awarn_ban_threshold 5
awarn_ban_time 7200
awarn_decay 1
awarn_decay_rate 10080
awarn_reasonrequired 1
