Author Topic: AWarn2 - Advanced Warning Module  (Read 603557 times)
Offline Fanney
Re: AWarn2 - Advanced Warning Module
« Reply #75 on: June 29, 2014, 01:10:25 pm »
Hey, are you able to add some hook.Run's to following method(s)?
- If the Player connects and his warnings are received.
- If a player's warning count updates
Because then i would be able to release some modules w/o my edited source, also is there a global for receiving the current warns?
Nice Plugin btw ;')
Offline CodeNil
« Reply #76 on: July 02, 2014, 01:39:08 pm »
This is an incredibly useful module, works amazingly for my server, have a few suggestions though, could you add a way to remove a specific warn by right clicking it in the menu? And also could you make it tell you who you were warned by and why when you get kicked/banned for warning exceeded?
Offline jase240
« Reply #77 on: July 12, 2014, 03:56:23 am »
Hey nice plugin, but sadly the TTT module still does not work. I have tried installing it on my server like you explained in OP and nothing happens.
« Last Edit: July 12, 2014, 04:07:13 am by jase240 »
« Reply #78 on: July 12, 2014, 03:35:45 pm »
I think the TTT module throws an error. I haven't had the time to look into it. Sorry. I'll post here when I have a chance to fix the modules.
Offline Mr.Waffle
« Reply #79 on: July 21, 2014, 03:53:36 pm »
My auto warn for team killing module is not working, I have it in the correct folder but yet it still doesnt work when someone team kills.
« Last Edit: July 21, 2014, 04:04:17 pm by Mr.Waffle »
Offline DEAD_KARL
Re: AWarn2 - Advanced Warning Module Help
« Reply #80 on: July 28, 2014, 01:07:18 pm »
Hi
I love this addon and I am very grateful for you coding it. But when I try sue it nothing happens.
I am a superadmin and when I type "!warn" nothing happens, please could I get help?
Thanks DEAD KARL
Extra:
// says this = [ERROR] addons/awarn2(dev)/lua/autorun/sh_awarn.lua:14: '=' expected near 'groupallow'
  1. unknown - addons/awarn2(dev)/lua/autorun/sh_awarn.lua:0
« Last Edit: July 28, 2014, 02:16:30 pm by DEAD_KARL »
« Reply #81 on: July 28, 2014, 07:26:42 pm »
Hi
Thanks DEAD KARL
Extra:
That error makes no sense. There isn't anything remotely close to 'groupallow' near line 14 of that file.. or anywhere IN that file. make sure you have the latest version. Also, make sure you're installing it correctly.
Offline Fluttershy
« Reply #82 on: August 02, 2014, 09:19:16 pm »
So right now, the warn system has its own little GUI, That's cool. However it was a little confusing at first because I couldn't find it in the XGUI, other than the AWarn permissions. For now they are only console commands? It would be cool if the GUI could be added in the XGUI like the ban list in ULX, and if the actual act of warning someone could be accessed under ULX utility like the old one.
« Reply #83 on: August 02, 2014, 10:09:57 pm »
AWarn2 has compatibility with ULX user groups and permissions, but it's completely stand alone. That's why it isn't in XGUI and that's also why I won't be adding it to XGUI.
Offline the agent modz
« Reply #84 on: August 03, 2014, 02:33:56 pm »
i added folder to the addons folder and restarted it and nothing happened
« Reply #85 on: August 03, 2014, 02:44:28 pm »
What folder did you add to the addons folder?
Offline Storm
« Reply #86 on: August 04, 2014, 08:21:10 am »
the agent, do you have another addon that has a warn function or do you have the original awarn?
Offline UnderYouFive
« Reply #87 on: August 05, 2014, 02:56:32 pm »
How do you make it so Mods can use warn? I changed the sh_awarn.lua "ADMIN" to MOD but it doesn't work.
« Reply #88 on: August 05, 2014, 07:46:06 pm »
Don't change anything in sh_awarn.lua you will just break the script.
If you want to assign permissions, look at the main post for how to add new groups. It's quite easy if you have ULX.
Offline xombob
« Reply #89 on: August 06, 2014, 04:36:52 am »
When I installed this I tested it on myself (as in gave myself a warning) and I cant erase that warning now O_o. May have something to do with the fact that I changed to mysql between (I think, it was a while ago) but even after changing back in the sqlite and trying to clear the warning it still doesnt go away. Well - it did go away from the menu saying I have no warnings but when I connect on the server it still displays the warning in the chat area. Strange.
