Author Topic: ULX ULIB fatal error  (Read 7303 times)
Offline 00face
« on: March 17, 2014, 06:48:03 pm »
Getting the following error, running a dedicated server:
[WAC Aircraft] lua/entities/wac_hc_base/cl_init.lua:429: attempt to index field 'wac' (a nil value)
  1. MovePlayerView - lua/entities/wac_hc_base/cl_init.lua:429
   2. fn - lua/autorun/client/wac_aircraft.lua:87
    3. unknown - addons/ulib/lua/ulib/shared/hook.lua:183
Crashes me with too many errors.
Any help would be appreciated, please feel free to contact me via steam @  00face as I've been working on getting all this working for days x).
Re: ULX ULIB fatal error
« Reply #1 on: March 17, 2014, 08:09:28 pm »
Though I've no clue what wac is without seeing/knowing the code (and no, I don't want to see it), you'd likely get almost the exact same error, minus mention of ULib hook.lua, if you were to remove Ulib and ULX from your server addons.
The error is pretty precise.
The wac table index is blank when it's being run.
Mr582
« Reply #2 on: March 18, 2014, 11:42:16 am »
WAC Community is a Addon on the workshop :)
Offline Cobalt
« Reply #3 on: March 18, 2014, 12:52:00 pm »
This has nothing to do with ULib. The only reason you see it in the error is because ULib overrides the default hook system. This is an error with WAC.
