Author Topic: restrict amount of targeted users  (Read 6010 times)
Offline Avoid
« on: March 22, 2014, 06:09:21 pm »
Hello there,
I'd like to know if it is possible to restrict the slap command for instance, so only one user can be targeted at a time?
 I want it so moderators cannot use "!slap *".
Thanks in advance,
Avoid
Re: restrict amount of targeted users
« Reply #1 on: March 24, 2014, 11:23:34 am »
Unfortunately I don't believe this can be done with stock ULX. There are three things you could try:
 - Modify the ulx slap command to only allow one target player, but that would affect admins and superadmins as well.
 - Make a duplicate of the ulx slap command with a slightly different name, then modify that to only allow one target. Give your moderators access to the duplicate command instead of the regular ulx slap.
 - Modify the ulx slap command to make it only slap one target from the input if the calling player is in a specific group. This one will do what you want without a separate command, but the groups will have to be hard-coded in the script, and it's a little more involved.
Offline ojbristow
    • Superclocked
« Reply #2 on: March 24, 2014, 12:23:41 pm »
Would you not just change the can target for that one command for moderators? So in the box when you click the command in XGUI have the can target !%rankname - then for the next rank up you would remove the restriction?
Owen
« Reply #3 on: March 24, 2014, 03:13:59 pm »
Owen
What he means is he wants to be able to set a number of users that can be targeted at one time, regardless of can_target. So, if !slap * was performed, there would be an error message if > x players were online, x being the restriction on allowed targets per command.
In metaphor form, he wants to be able to give his usergroups a gun, but only give them a certain amount of bullets per magazine (sorry if not G).
Offline ojbristow
    • Superclocked
« Reply #4 on: March 24, 2014, 04:25:05 pm »
Ah, well, I should probably stop trying to help people :P
My only suggestion then would be to only give them commands to people you trust.
Owen
« Reply #5 on: March 24, 2014, 07:46:17 pm »
We've been preaching to the choir about this for years.
Unfortunately, it seems the congregation wants everyone to be superadmins or similar.  :/
Offline Avoid
« Reply #6 on: March 25, 2014, 09:45:51 am »
Hello,
Thanks for all those answers!
I do trust my moderators, as I do not give out permissions to people who I do not trust.
I just wanted to know if this is possible or not!
So I guess I will try to edit the command itself.
Thanks a bunch,
Avoid
