Author Topic: Bulk Upload of steamID's to ULX Group  (Read 8603 times)
Offline nzkfc
« on: April 03, 2014, 11:24:22 pm »
Hi,
I know there is a file containing users in their respective ULX groups.
Is there a way to bulk add a range of users to a group, I have 300+ users I need to add in and don't want to do it maunally.
I used a script to copy them into a file but it didn't work.
Offline Neku
Re: Bulk Upload of steamID's to ULX Group
« Reply #1 on: April 03, 2014, 11:43:12 pm »
Why and how do you have 300+ users to add into ULib?
Don't get me wrong, I do want to help, but there's no way for me to do so
with only this amount of information.
« Reply #2 on: April 04, 2014, 03:58:55 pm »
Possibly changing things around on his server, most likely.
I'm confused as to what you need from him- he has a bunch of SteamIDs that he wants to move form one group to another. I interpreted that fine... hmmm...
« Last Edit: April 06, 2014, 11:32:29 pm by Stickly Man! »
Offline Neku
« Reply #3 on: April 04, 2014, 05:58:59 pm »
I'm asking how he has obtained 300+ Steam IDs.
And if he is moving from another admin mod.
« Reply #4 on: April 04, 2014, 06:09:45 pm »
Ahhhhhh, okay. That makes more sense.
I'm tired today- ignore my stupidity. :P
« Reply #5 on: April 04, 2014, 09:45:35 pm »
ULX has no default method to add many at once.
Though Ulib's users.txt file is easy to see what it does, the simplest method would be to use Gmod's normal user.txt file and format.
Issue is, I don't remember if we(ULX) will store them in ULX own user files, so that you could remove them from Gmod's, and change/promote them later using only ULX.
(I know we load Gmod's at startup)
As for the amount, yeah, just crazy, but, to each their own.
Gmod users.txt file is this format, in gmod_server_path/settings/users.txt
"Users"
"<groupname01>"
"<playername01" "STEAM_0:1:###1",
"<playername02" "STEAM_0:1:###2",
"<groupname02>"
"<playername03" "STEAM_0:1:###3",
"<playername04" "STEAM_0:1:###4",
Offline nzkfc
« Reply #6 on: April 10, 2014, 06:34:11 pm »
Hi,
300+ users are donators to the server, so I need to add them to donator rank so they can use jobs/tools etc.
OK so manual is the only way, I can write a script to automate that from a excel sheet.
Question I have though, do I HAVE to have a player name or can I leave it blank (e.g. what happens when you add a steamID to a rank and they have not connected, I assume it updates the file once he connects with a player name to his already added steamID.
Cheers
« Reply #7 on: April 11, 2014, 10:25:27 am »
Hi,
Cheers
Yes you are correct, it will add the name once they connect. As for adding those 300 users try using a for loop.
Offline nzkfc
« Reply #8 on: May 29, 2014, 12:39:42 am »
Sorry to necro the thread.
I just wanted to check if this code layout would still be read correctly?
http://imgur.com/rhf2gk1
Offline nzkfc
« Reply #9 on: June 06, 2014, 06:43:55 pm »
Anyone?
Offline Valgoid
  • Wanna Be Lua King
« Reply #10 on: June 11, 2014, 09:21:20 am »
Have you tried the code yet?
Offline nzkfc
« Reply #11 on: June 17, 2014, 12:47:49 am »
Yeah but I think it caused a bunch of issues so I stopped using it.
We made a automatic donation system instead. Ulx really needs a bulk group add tool.
