Author Topic: ULX not loading settings  (Read 4008 times)
Offline fgblomqvist
« on: April 06, 2014, 04:19:56 am »
ULX is a great addon, but I can't get it to load my settings.
I have attached the ulx directory that is in my data folder (the server's data folder that is).
I don't care much about the "global" settings, I just want the gamemode specific settings to work. As it is now, it doesn't load them (because the maps that you can choose from don't change).
Could anyone with more knowledge than me verify that everything is as it should? I am using the latest ulx (3.61).
Re: ULX not loading settings
« Reply #1 on: April 11, 2014, 07:37:41 pm »
Are you sure the gamemode name in this case is prop_hunt? Try loading the config for a certain map instead just for a sanity check.
