Author Topic: Problem  (Read 5029 times)
Wyrmfell
Problem
« on: February 19, 2007, 10:55:27 am »
I was given superadminship by a server hoster. I have downloaded ULX. However, when I play, the console commands dopn't work. This is weird because the menu works when I say "!menu", but when I type ulx menu into the console it says
Unknown command: ulx.
Offline Thud13
Re: Problem
« Reply #1 on: February 19, 2007, 12:24:00 pm »
Follow this guide here to set it up:
http://garrysmod.com/wiki/?title=Admin#Dedicated_Servers
Double and triple check your steam ID to be absolutely certain you put in the right one.
I've had that problem actually occur even WITH admin setup correctly. Simply restart the server and try again.
Offline spbogie
Re: Problem
« Reply #2 on: February 19, 2007, 02:57:34 pm »
Are there any errors (CLIENT or SERVER) on startup? Can anyone else use the commands? do you see "unhandled usermessage: ulib_autocomplete" or similar in console after connecting?
You are likely experinecing a well known bug that we have, as of yet, been unable to track down. http://ulyssesmod.net/bugs/view.php?id=20.
