Author Topic: Restrict Certain Props  (Read 7857 times)
Offline Thud13
« on: February 19, 2007, 12:25:29 pm »
Was just curious- people on my server have the new hobby of crashing my server with explosive barrels. Its annoying, and I can't do anything about it.
And I was wondering if this feature was already built in:
Is it possible to create a way to limit the amount of explosive barrels that can be created? 10 Barrels max IMO would be a good number.
If it doesn't have this feature built in, could anyone point me in the right direction to code up something simple? Its really becoming an issue fast.
Re: Restrict Certain Props
« Reply #1 on: February 19, 2007, 12:53:00 pm »
Here's a very basic one..
  1. local models = {}
  2.
  3. function restrictProp( prop, number )
  4.         models[ prop ] = number
  5. end
  6.
  7. local function blockProps( ply, mdl )
  8.         if not models[ mdl ] then return end -- Not blocked
  9.         ply.mdlCount = ply.mdlCount or {}
  10.         ply.mdlCount[ mdl ] = ply.mdlCount[ mdl ] or 0
  11.         if ply.mdlCount[ mdl ] >= models[ mdl ] then ply:PrintMessage( 3, "You're over your limit for this prop!" ) return false end
  12.         ply.mdlCount[ mdl ] = ply.mdlCount[ mdl ] + 1
  13. end
  14. hook.Add( "PlayerSpawnProp", "blockProps", blockProps )
  15. restrictProp( "models/props_c17/oildrum001_explosive.mdl", 10 )
  16.
Doh, just realized this code won't free the numbers as the prop is deleted, but the gmod wiki is down right now so I can't look up the hook. I'll fix it when it's back up.
« Last Edit: February 19, 2007, 12:55:58 pm by Megiddo »
Offline Thud13
« Reply #2 on: February 19, 2007, 02:47:26 pm »
You guys are really awesome. Thank you for being so kind.
« Reply #3 on: February 22, 2007, 12:49:19 am »
Okay, here's the final version of this quick hack.
  2.
  5. end
  6.
  12.                 ply:PrintMessage( 3, "You have reached the limit for this prop (" .. models[ mdl ] .. ")" )
  13.                 return false
  14.         end
  15.         ply.mdlCount[ mdl ] = ply.mdlCount[ mdl ] + 1
  16. end
  17. hook.Add( "PlayerSpawnProp", "block.blockProps", blockProps )
  18.
  19. local function recordProps( ply, mdl, ent )
  20.         if not models[ mdl ] then return end -- Not blocked
  21.         ent.blockOwner = ply
  22. end
  23. hook.Add( "PlayerSpawnedProp", "block.recordProps", recordProps )
  24.
  25. local function propRemoved( ent )
  26.         if ent.blockOwner then
  27.                 local mdl = ent:GetModel()
  28.                 local ply = ent.blockOwner
  29.                 ply.mdlCount[ mdl ] = ply.mdlCount[ mdl ] - 1
  30.         end
  31. end
  32. hook.Add( "EntityRemoved", "block.entRemoved", propRemoved )
  33.
  34. local function tool( ply, tr, toolmode )
  35.         if toolmode == "magnetise" and tr.Entity.blockOwner then
  36.                 ply:PrintMessage( 3, "You cannot magnetize this prop, sorry." )
  37.                 return false
  38.         end
  39. end
  40. hook.Add( "CanTool", "ULXToolCheck", tool )
  41.
  42. restrictProp( "models/props_c17/oildrum001_explosive.mdl", 10 )
Just call the restrictProp() function with what you want. Note that a really easy way to get around this protection is to rejoin... but hey, we're going for simple here.
Offline Dr.Roxor
« Reply #4 on: March 01, 2007, 11:37:43 am »
I'm trying to call the restrictProp() function in multiple lines for various props like this:
restrictProp( "models/props_c17/oildrum001_explosive.mdl", 5 )
restrictProp( "addons/phx/models/props_phx/amraam.mdl", 2 )
restrictProp( "addons/phx/models/props_phx/torpedo.mdl", 2 )
But I must not be able to "see" the addons/phx/models/props_phx folder, because this restriction for the phx models is not working. The restriction on the oildrum works however. Can anyone help me on this? I have tried various ways without success. Thanks for any tips.
EDIT: Nevermind I figured it out. The problem was in my path. Below is the correct way, noting the extra forwardslash as being what solved it for me:
restrictProp( "addons/phx/models//props_phx/amraam.mdl", 2 )
restrictProp( "addons/phx/models//props_phx/torpedo.mdl", 2 )
« Last Edit: March 01, 2007, 11:52:28 am by Dr.Roxor »
« Reply #5 on: March 01, 2007, 04:22:35 pm »
Hmm odd, I'd think that you'd drop the addons/phx/ part entirely.
Offline Dr.Roxor
« Reply #6 on: March 01, 2007, 06:50:03 pm »
Perhaps it works both ways. I know it is working as shown in my snippet above.
