Author Topic: Fadmin and Ulx not working  (Read 4793 times)
Offline Jason1337
« on: April 11, 2014, 04:51:55 pm »
So I want my rank system to be as followed:
User> Supporter > Moderator >Admin> Super Admin > Rootadmin > Owner
I have the inheritance and settarget configured correctly, its just that when I set the rank, even though I make an fadmin group with the same name, it only gives me the tab menu settings such as slay when I make the group inherit from operator, admin, and superadmin. Is there a way to make fadmin group and ulx group sort of work together, for ezample if I have a fadmin group that had only slay, and a ulx group with other settings, combine into one when I actually promote someone?
Re: Fadmin and Ulx not working
« Reply #1 on: April 11, 2014, 05:11:50 pm »
There are known conflicts between FAdmin and ULX. It's not advised to run more than one admin mod on a server as since they perform a lot of the same functions there are sure to be conflicts.
Also, by having superadmin not be your top group you are setting yourself up for failure in the long run. (but I'm done preaching that point)
Offline Jason1337
« Reply #2 on: April 11, 2014, 05:37:34 pm »
Yes I understand. Thanks for replying so fast :)
