Author Topic: Why the am i having valve.rc not executing on my garrys mod deicated source  (Read 10655 times)
Offline Lewis
dear helpers,
I tried removing valve.rc file and add it back again but when i run my server i always get valve.rc not present; not excecuting can anyone fix this plzzz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I also did some adding but im sure i didnt do anything wrong because i just deleted that and it still happens to be there...
Thanks Lewis
Can you please post the code you use to both start your server and update your server?
Remember to surround them in [code][/code] tags.
Offline Lewis
@echo off
cls
echo Protecting srcds from crashes...
echo If you want to close srcds and this script, close the srcds window and type Y depending on your language followed by Enter.
title srcds.com Watchdog
:srcds
echo (%time%) srcds started.
start /wait srcds.exe -console -game garrysmod +map gm_flatgrass +maxplayers 32
echo (%time%) WARNING: srcds closed or crashed, restarting.
goto srcds
@echo off
cls
:srcds
goto srcds
Do you have your update script as well?
Also, code tags work like this:
[code]<your code here>[/code]
:P
Offline Lewis
what one??
what one??
What code do you use to update your server files?
(How did you install your server?)
Offline Lewis
STEAMCMD
Hm...
Try adding validate to the end of app_update.
Example:
app_update 4020 validate
If you use a shell or batch script, add a + in front of app_update. Otherwise, leave it out.
Offline Lewis
Thank you it worked perfectly!
Topic closed!
Problem sorted
