Author Topic: How do I make it so admins press v to turn noclip on  (Read 24271 times)
Offline jkarateking
« on: April 20, 2014, 03:05:48 pm »
At the minute my admins have to write !noclip to turn noclip on and off. How do I make it so they only have to click v to turn it on and off.
Thanks in advance
Offline Zmaster
Re: How do I make it so admins press v to turn noclip on
« Reply #1 on: April 20, 2014, 03:20:53 pm »
-snip-
forgot about: bind v ulx noclip
« Last Edit: April 20, 2014, 06:02:08 pm by Zmaster »
Offline coolwithpie
« Reply #2 on: April 20, 2014, 03:26:47 pm »
just doing this off the top of my head but couldn't you bind v to "ulx noclip"?
i dont know if this is the command b/c i cant get on gmod ATM but this should work.
« Reply #3 on: April 20, 2014, 04:29:16 pm »
As coolwithpie said, you can tell your admins to use "bind v ulx noclip" in their console. Keep in mind that this will override the default "noclip" used by sandbox.
« Reply #4 on: April 20, 2014, 09:15:33 pm »
bind v "noclip ; ulx noclip"Will work on any server that has noclip enabled OR you have ulx access to noclip.
Will spit out the appropriate errors on failure of either, but won't override the default key, just adds to it.
Offline Neku
« Reply #5 on: April 20, 2014, 10:30:06 pm »
If this is used on a sandbox server with ulx installed, the commands will negate each other.
You know, if both ways to no clip are enabled.
