Author Topic: ULX LogEcho Not working  (Read 6280 times)
Offline Steekster
« on: April 25, 2014, 01:06:46 am »
Just started up my new server and when ever someone is killed with a prop it doesn't show in console like it usually would nor does it show any kills/deaths.  This is my Data>ULX>Config.lua
ulx logFile 1 ; Log to file (Can still echo if off). This is a global setting, nothing will be logged to file with this off.
ulx logEvents 1 ; Log events (player connect, disconnect, death)
ulx logChat 1 ; Log player chat
ulx logSpawns 1 ; Log when players spawn objects (props, effects, etc)
ulx logSpawnsEcho 1 ; Echo spawns to players in server. -1 = Off, 0 = Dedicated console only, 1 = Admins only, 2 = All players. (Echoes to console)
ulx logEcho 1 ; Echo mode
ulx logJoinLeaveEcho 1 ; Echo players leaves and joins to admins in the server (useful for banning minges)
ulx logDir "ulx_logs" ; The log dir under garrysmod/data
; Echo modes:
; 0 - OFF No output to any players when an admin command is used
; 1 - ANONYMOUS Output to players without access to see who used the command (admins by default) similar to "(Someone) slapped Bob with 0 damage"
; 2 - FULL Output to players similar to "Foo slapped Bob with 0 damage"
ulx logEchoColors 1 ; Whether or not echoed commands in chat are colored
ulx logEchoColorDefault "151 211 255" ; The default text color (RGB)
ulx logEchoColorConsole "0 0 0" ; The color that Console gets when using actions
ulx logEchoColorSelf "75 0 130" ; The color for yourself in echoes
ulx logEchoColorEveryone "0 128 128" ; The color to use when everyone is targeted in echoes
ulx logEchoColorPlayerAsGroup 1 ; Whether or not to use group colors for players. If false, it uses the color below.
ulx logEchoColorPlayer "255 255 0" ; The color to use for players when ulx logEchoColorPlayerAsGroup is set to 0.
ulx logEchoColorMisc "0 255 0" ; The color for anything else in echoes
Any help to fix this would be amazing! Thanks!
Offline Neku
Re: ULX LogEcho Not working
« Reply #1 on: April 25, 2014, 07:51:28 am »
That's not ULX.
Offline Fobro879
« Reply #2 on: July 27, 2016, 10:48:38 am »
you have to type ulx_logecho 1 (Add an underscore)
ulx_logecho 0 simply disables the messages in chat
Offline Undercover Orange
« Reply #3 on: July 27, 2016, 12:16:28 pm »
go get an anti prop kill for your server. you can pay for one or find a free one. or (SUGGESTION REMOVED)
« Last Edit: July 27, 2016, 03:03:31 pm by JamminR »
~ Undercover Orange
« Reply #4 on: July 27, 2016, 03:06:53 pm »
undercoverorange, suggestions like you made (that I removed from your post) will not be tolerated here.
Team Ulysses fully supports those who wish to charge for their work, even when and if we as team individuals may disagree with the idea.
We are developers. We all demand payment in various forms, even if not standards currency such as money.
Steekster, honestly, such as Neku states but very shortly, though the config you show is indeed ULX, I'm reasonably sure the death notices are not controlled by ULX.
« Last Edit: July 27, 2016, 03:09:27 pm by JamminR »
« Reply #5 on: July 27, 2016, 03:10:36 pm »
As do I. Which is why I had said I don't suggest doing it. I myself am one of the people who goes around looking for leaks so I can report them.
~ Undercover Orange
