Author Topic: Suggestion  (Read 12741 times)
Offline Jesusaurus-Rex
Suggestion
« on: December 23, 2005, 12:39:59 pm »
  • Bother Megiddo to re-enable or add an option to re-enable the weapon menu (the feature I used more then anything else in ulx, and tried for hours to get working again).
  • Bother Megiddo to add a disable forcedownload option.
  • Bother Megiddo to add a tutorial for forcedownload.
  • Bother Megiddo to fix forcedownload.
  • Bother Megiddo to add an admin level system like IRC (For example: lvl 200 can't kick lvl 300).
  • Bother Megiddo to add _OnAdminJoin(settings change)
  • Bother Megiddo to add a gun list to auto-give to admins on join.
  • Bother Megiddo untill his eyeballs fall out.
« Last Edit: December 23, 2005, 01:00:02 pm by Megiddo »
Re: Suggestion
« Reply #1 on: December 23, 2005, 01:03:29 pm »
Uncomment the code in ulx_menus.lua
Delete forcedownload.txt
The comments in the file are enough
It works fine for maps that have a .res ( gm_construct, for example ) in the current version, and in the next version it will be fixed for maps that don't already have a .res set up as well
Not enough interest to add to main ULX, ask someone else if they'd like to make an addon.
Re: Suggestion
« Reply #2 on: December 23, 2005, 01:11:40 pm »
Quote from: Megiddo
What do you thnk I tried to do?
Quote from: Megiddo
You can't add an option in config.lua ?
Quote from: Megiddo
Well, why isn't it working for me? Is mani causeing compatibility problems?
Quote from: Megiddo
Unhappy Face.
