Author Topic: jail tp to coördinates  (Read 19468 times)
Offline ULXGmodFan
Re: jail tp to coördinates
« Reply #15 on: June 08, 2014, 02:47:49 am »
I tried, but same error, no jailpos is set for the map
Offline Neku
« Reply #16 on: June 08, 2014, 10:31:47 am »
Oh. I feel stupid.
Go into the lua file and find
"jailtp" .. game.GetMap() .. ".txt"This should be the one in the jailtp command. Replace "jailtp" with "jailtp/".
Offline ULXGmodFan
« Reply #17 on: June 10, 2014, 12:40:10 pm »
Thanks alot, that worked!
Now can I remove the bars somehow so it uses the jail in the level?
Offline Neku
« Reply #18 on: June 10, 2014, 01:14:13 pm »
Oh. In that case, let me rewrite it.
Offline ULXGmodFan
« Reply #19 on: June 11, 2014, 07:06:47 am »
Rewrite? The lua addon now works, but i wouldn't recommand for others to use because they miss a slash in the code.
But I was wondering if I could just remove the prop fence models and if the jail still works but you can freely walk around in the mapjail instead of the 6 fences. Would the other stuff still work like not being able to use weapons and tools etc?
Thanks
Offline Neku
« Reply #20 on: June 11, 2014, 07:44:38 am »
There is. ULX spawns in those fences, so comment them out.
