Author Topic: ULX Observation Mode  (Read 30638 times)
Offline Neku
« on: May 28, 2014, 08:10:57 pm »
ULX Observation Mode - 1.2
This adds a command into the utility tab called ulx observe. It places the target into Observation Mode, making them noclipped, godded, and invisible. This also stores the target's location and restores it upon reuse. If no target is defined with the chat command, it will target the person calling the command.
I made this for a guy on coderhire, but since it was easy to do, I did it for free.
Link to the job
  • 1.2 - Fixed an oversight on the cloaking amount.
  • 1.1 - Fixed critical bug relating to EyePos and EyeAngles. Also made noclip simpler. (Thanks Cobalt!)
  • 1.0 - Inital Release
« Last Edit: June 07, 2014, 08:50:14 pm by Neku »
Offline Cobalt
Re: ULX Observation Mode
« Reply #1 on: May 29, 2014, 12:14:01 pm »
ULX Observation Mode - 1.0
Link to the job
Instead of running a console command just do this:
target_ply:SetMoveType( MOVETYPE_NOCLIP )
and
target_ply:SetMoveType( MOVETYPE_WALK )
Offline Zombine
« Reply #2 on: June 01, 2014, 08:53:36 pm »
Well I finally got around to nagging my server manager to put it in, and when using it I get this:
[ERROR] addons/ulx/lua/ulx/modules/sh/observation.lua:12: attempt to call method 'GetEyePos' (a nil value)
  1. call - addons/ulx/lua/ulx/modules/sh/observation.lua:12
   2. __fn - addons/ulib/lua/ulib/shared/commands.lua:943
    3. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
     4. unknown - lua/includes/modules/concommand.lua:69
Offline Neku
« Reply #3 on: June 01, 2014, 09:21:07 pm »
I'll take a look at that, I don't think your eye position is needed anyway.
Offline Cobalt
« Reply #4 on: June 01, 2014, 11:10:27 pm »
It's not GetEyePos(), just EyePos()
Offline Neku
« Reply #5 on: June 01, 2014, 11:21:44 pm »
Alrighty, I fixed that issue up. Thanks Cobalt!
Offline Zombine
« Reply #6 on: June 02, 2014, 08:17:17 pm »
Is there any way the weapon could be made invisible, too? Or is that not a possibility with ULX functions?
Offline Neku
« Reply #7 on: June 02, 2014, 08:22:37 pm »
They should be invisible too.
Offline Zombine
« Reply #8 on: June 04, 2014, 02:33:39 pm »
No, unfortunately the weapons are not invisible. As well, I can still slightly see people in observer mode, almost as if they have the vol_light material on.
« Reply #9 on: June 05, 2014, 07:34:08 am »
Zombine, providing a bit more information would help greatly.
What gamemode? Do you use any addons that would affect the way a player looks visually?
Do you use any addons that do _anything_ with weapons? Is it all weapons, or custom ones? Which ones?
It sounds like this release works, perhaps just not in your server environment due to gamemode and or addon conflict.
Offline Zombine
« Reply #10 on: June 05, 2014, 10:13:10 pm »
Sandbox gamemode, no external player modification, and -all- weapons show up. I'm looking through a camera, if that helps, if for any reason cameras don't properly show invisiblity.
Offline Neku
« Reply #11 on: June 05, 2014, 11:41:30 pm »
Try running ULX Cloak on yourself and see if the guns still appear.
Offline Zombine
« Reply #12 on: June 06, 2014, 06:28:38 pm »
ULX Cloak works just fine, but observer mode does this:
Offline Neku
« Reply #13 on: June 07, 2014, 08:48:07 pm »
<snip>
Alright, I overlooked that the amount that would cloak you by was 255 subtracted by the amount.
I fixed this in the update. Hopefully, this will be the last update! (Unless Garry breaks things.)
I don't know about the weapons though.
« Last Edit: June 07, 2014, 08:51:59 pm by Neku »
Offline Zombine
« Reply #14 on: June 08, 2014, 07:53:40 pm »
Well whatever you did to the fix the cloaking fixed the weapons issue with it!
It's absolutely perfect now, thank you so much for all of your help!
