Author Topic: AAFK V_3.1: How to remove ulx.fancyLogAdmin?  (Read 5575 times)
Offline Exile
« on: June 05, 2014, 06:25:48 pm »
Today, I was wondering on how to remove this below correctly.
ulx.fancyLogAdmin( pl, "#A went AFK." ) Every time someone would go AFK, it would display on player's screen the ulx message (Someone) went AFK, then the message original message from the script. I removed that part of the script and then the script broke, how do we fix this? Thanks.
Re: AAFK V_3.1: How to remove ulx.fancyLogAdmin?
« Reply #1 on: June 05, 2014, 07:06:53 pm »
Removing the fancy log shouldn't break the script. It might be you removed something else you shouldn't have.
Try again to just remove that line.
Offline Exile
« Reply #2 on: June 05, 2014, 07:35:43 pm »
Oh, btw, when a player is pushed from a prop, they're afk status comes off, even though they are still afk, will there be a fix soon for that?
« Reply #3 on: June 05, 2014, 10:19:56 pm »
AAFK is something I wrote a long time ago. There hasn't been (nor will there be) an update in a long time.
I have some ideas on how to completely revamp this plugin, and that's the direction I will take if I decide to update it at all.
