Author Topic: players pick each other physgun  (Read 4998 times)
Offline dimon
« on: June 11, 2014, 04:00:22 am »
I created a server gamemode DarkRP  and set the admin ULX. Join people and began to lift each other physgun. In the admin ticked off ulx physgunplayer but people still can lift each other. What to do?
Offline Valgoid
  • Wanna Be Lua King
Re: players pick each other physgun
« Reply #1 on: June 11, 2014, 09:15:46 am »
What is the default ulx group on your server?
« Reply #2 on: June 11, 2014, 09:59:11 pm »
Also, DarkRP has all kinds of group issues with ULX due to it including it's own admin mod by default.
If you find a way to disable the DarkRP admin mod, ULX might work better for you if you haven't tried creating groups higher than superadmin.
Offline dimon
« Reply #3 on: June 12, 2014, 12:20:49 am »
Group user
Offline dimon
« Reply #4 on: June 12, 2014, 01:14:11 am »
I understood the reason. It's all because DarkRP Admin mod. I cleaned ULX and players could still raise each other.  >:(  :-\  :(
Offline Valgoid
  • Wanna Be Lua King
« Reply #5 on: June 12, 2014, 09:41:43 pm »
You can disable the FAdmin Mod on DarkRP servers by installing the darkrp modifications, and set the config file in there for FAdmin to true, which will disable it
