Author Topic: People are banned and cannot be unbanned  (Read 4493 times)
Offline Fifty44
« on: June 30, 2014, 03:14:54 pm »
The problem is people get banned - and then after unbanning them, it keeps giving them the source message "You have been banned from the server." for awhile, then maybe a day later they're unbanned.
I have had ULX and UGB Module ( http://facepunch.com/showthread.php?t=1300982 ) for awhile now but I don't think UGB is causing the issue. UGB has it's own ban message that displays a reason if it's preventing you from connecting, I don't know if ULX is the issue either as with both times I've encountered this issue (that people have come to me instead of just not bothering and going to another server) they haven't been in ULib's bans.txt or the banned_user.cfg. I'm out of ideas of what could possibly be keeping them from connecting.
Offline Avoid
Re: People are banned and cannot be unbanned
« Reply #1 on: June 30, 2014, 06:47:33 pm »
Hello there,
output from listid + listip command?
I am quite sure this is caused by your UGB module, as ULX bans work perfectly fine. - The OP has not replied to any posts for a while now.
I'd recommend you to use a bansystem like SourceBans there is an ULX module for it on FP.
Cheers,
Avoid
Offline Fifty44
« Reply #2 on: June 30, 2014, 08:31:54 pm »
I'll try making a switch to SourceBans and see if that fixes it - thanks for the advice, you're probably right. List ID outputs ID filter list: empty.
Offline Fifty44
« Reply #3 on: July 01, 2014, 05:39:57 am »
Sorry for a double post - I'm having a TON of trouble hooking SourceBans up to ULX - can you give me the easiest way to do it ? Thanks. I tried this method https://www.youtube.com/watch?v=tGP5DSO6EDU but it worked really well out of the box but bans wouldn't sync. I tried putting in the command myself but I'm an idiot apparently and it kept spitting out different errors.
« Last Edit: July 01, 2014, 05:44:15 am by Fifty44 »
Offline Avoid
« Reply #4 on: July 01, 2014, 06:01:50 am »
I am using this aswell as SourceBans Version 1.4.11.
Just remove the ban permissions from the other groups, as this module comes with sban and sbanid!
Hope I helped,
Avoid
Offline Fifty44
« Reply #5 on: July 01, 2014, 06:26:25 am »
Yeah, thanks for the quick responses!
