allow only ulx ranks or usergroup on server
Topic: allow only ulx ranks or usergroup on server (Read 3859 times)
raymond4000
July 06, 2014, 04:55:31 pm »
I was wondering if anyone knows of a way to only allow users on a server that only have a rank or certain user group.
So in other words you would be unable to join the server unless you were apart of a specific usergroup.
Thanks!
Avoid
Full Member
Re: allow only ulx ranks or usergroup on server
July 06, 2014, 07:06:57 pm »
Hello,
you should take a look at the PlayerAuthed hook
here
So now you only need the check the players usergroup and kick disallowed usergroups accordingly.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #2 on:
July 06, 2014, 09:57:33 pm »
I'm pretty sure you could enable ULX reserved slots in mode 1 with slots avail as same number of server maxplayers and perform same function.
Then you'd have to grant any of the groups (or inherit from another) the reserved slot access. "ulx reservedslots" I think.
Or maybe that's mode 3.
I always get them mixed up.
https://github.com/Nayruden/Ulysses/blob/master/ulx/data/ulx/config.txt#46
<-- straight text config explanation, can be done in XGUI too though.
