ulx menu became an unknown command.
Topic: ulx menu became an unknown command. (Read 4726 times)
ler0ytjee
July 11, 2014, 02:41:33 am »
Hi.
I've had a problem the last 2 days where my ulx menu became a unknown command`.
but when i type in !menu this error comes
[ERROR] lua/includes/modules/net.lua:30: Received bad RPC, invalid function (xgui.toggle)!
1. func - [C]:-1
2. unknown - lua/includes/modules/net.lua:30
I hope you guys can guide me trough this.
Neku
Re: ulx menu became an unknown command.
July 11, 2014, 02:58:26 am »
This doesn't seem to be your typical problem. Have you made any changes directly to ULX? Specifically XGUI?
If not, please make sure that none of your addons are interfering with XGUI.
ler0ytjee
Reply #2 on:
July 11, 2014, 03:37:54 am »
I am sure that i haven't edited the ulx directory in any way.
Would uninstalling and reinstallign work or would it just do the same thing again
Avoid
Full Member
Reply #3 on:
July 11, 2014, 04:54:27 am »
Hello,
reinstalling ULX would eventually help, just make sure you pull from the latest repo. Also make sure to disable all addons and test out ULX with one addon at a time and you should find out what was causing this!
~Avoid
ler0ytjee
Reply #4 on:
July 11, 2014, 06:12:11 am »
Found the problem!
My server is a kind of democracy it's being ruled by 4 sa's and 1 co-owner.
3 poeple have acces t the FTP and it seemed 1 of them
with the ulx section.
Thank god i have a test server.
Neku
Reply #5 on:
July 11, 2014, 01:33:39 pm »
To prevent this from happening in the future, make sure they know what they're doing though.
Cobalt
Full Member
http://steamcommunity.com/id/__yvl/
Reply #6 on:
July 11, 2014, 01:46:41 pm »
"ulx menu" has never worked for me. I always just use "xgui"
