Author Topic: ULX Kick Self Crash  (Read 12132 times)
Offline Hollistupid
ULX Kick Self Crash
« on: July 13, 2014, 11:41:02 pm »
Whenever you kick yourself the server crashes  :(
VeryWetNoodle kicked Themself
Dropped VeryWetNoodle from server ([ULX] Kicked from server)
[ERROR] lua/includes/extensions/player.lua:141: Tried to use a NULL entity!
1. UniqueID - [C]:-1
2. GetPData - lua/includes/extensions/player.lua:141
3. fn - addons/customcommands/lua/ulx/modules/sh/cc_voting.lua:323
4. unknown - addons/ulib/lua/ulib/shared/hook.lua:183
Offline Hollistupid
Re: ULX Kick Self Crash
« Reply #1 on: July 13, 2014, 11:55:01 pm »
Oh my bad. Remove the "%", so it just says "!^". That should work.
Sorry for the mistake.
Restricting the kick command to not be able to kick self is a temp-fix for my problem and could be a permanent solution. But I still think this could be addressed.
« Last Edit: July 13, 2014, 11:57:42 pm by Hollistupid »
« Reply #2 on: July 14, 2014, 03:10:27 am »
I'm just letting you know that this has already been reported, so a fix will hopefully be here quite soon.
« Reply #3 on: July 14, 2014, 11:43:26 am »
As well as crashing issues here: /index.php/topic,7419.0.html
My theory is that chat commands are causing the issue- does the crash occur when called from console as well?
Also, do you use any sort of SQL-based banning system? It is likely a .dll module is causing the crash, but, I haven't been able to investigate yet.
Offline Avoid
« Reply #4 on: July 14, 2014, 12:00:52 pm »
Hello Stickly Man,
kicking yourself from the game console works fine, however, once you use the !kick/!ban chat command on yourself the server crashes.
So it definatley has something to do with the chatcommands.
~Avoid
« Reply #5 on: July 14, 2014, 12:35:59 pm »
I'm really thinking there's a third party addon causing this issue.. at least, I can't say for sure until I've tested myself. I'll see what I can find out later tonight! (Anyone else is welcome to try it on their own server with ULX only, if possible, to see if it still occurs).
Offline bender180
    • Benders Villa
« Reply #6 on: July 14, 2014, 03:46:39 pm »
I setup a new server with just ulib/ulx and i can confirm that when kicking yourself via chat command it does crash srcds, kicking yourself via xgui and console don't crash the server however.
« Reply #7 on: July 14, 2014, 05:23:18 pm »
I can also confirm on my own server that banning/kicking yourself through chat crashes the server, and I'm not running any other modules (other than lua addons, which haven't caused the issue before).
UPDATE: Also happens on my local SRCDS server with only ULib/ULX on.
« Last Edit: July 14, 2014, 05:34:56 pm by Decicus »
« Reply #8 on: July 14, 2014, 10:52:35 pm »
Oh yeah, it exploded severely.  :o
But it's fixed now! https://github.com/Nayruden/Ulysses/commit/cd02f4f44514d7f61e1d2b031689150fcc9cf588
I'm willing to bet this is an underlying issue in Garry's Mod itself, so I'm going to put together a simple script to see if I can replicate it...
« Reply #9 on: July 14, 2014, 11:15:13 pm »
Wow, yup- it's an issue with Gmod itself. Run this code on your server, and anyone who says "hi" will crash the server:
  1. local function playerSay( ply, text, private )
  2.         if text == "hi" then ply:Kick("") end
  3. end
  4. hook.Add( "PlayerSay", "test_say", playerSay, 20 )
« Last Edit: July 14, 2014, 11:17:13 pm by Stickly Man! »
Offline Avoid
« Reply #10 on: July 15, 2014, 04:49:57 am »
Thanks for the quick fixes Stickly!  :-*
Offline Hollistupid
« Reply #11 on: July 15, 2014, 12:27:31 pm »
Does not seem to be fixed:
Dropped Hollistupid from server ([ULX] Kicked from server)
« Reply #12 on: July 15, 2014, 01:13:20 pm »
Does it still crash the server? Or just display that lua error?
The cc_voting.lua (custom commands) file also has a hook into PlayerSay. Try temporarily removing that and see if your problem is fixed.
Offline Zmaster
« Reply #13 on: July 15, 2014, 02:14:54 pm »
I just tested it with the new ULX you linked, and it still crashes the server
« Reply #14 on: July 15, 2014, 02:27:03 pm »
I'm willing to bet it's a third-party addon issue- If you could temporarily remove any addons that might do something with the chat hook, that could help me test. If you get a lua error, that'd be helpful too. Otherwise I'd be willing to hop on any one of your servers when I have a moment to take a look myself.
