Author Topic: Ulx how to turn into a prop command?  (Read 4674 times)
Offline IcedKnife
« on: July 28, 2014, 03:28:06 pm »
I saw a admin turn into a prop and also it said in chat " (Someone) Has set player model prop/45/example/notaprop/ something like that i wish i took a picture
Offline Avoid
Re: Ulx how to turn into a prop command?
« Reply #1 on: July 28, 2014, 04:42:53 pm »
Hello,
you can do that quite easily with a custom ULX command, just take a look at SetModel.
For the (Someone) part, take a look inside your ULX config!
ulx logEcho 2 ; Echo mode
; Echo modes:
; 0 - OFF No output to any players when an admin command is used
; 1 - ANONYMOUS Output to players without access to see who used the command (admins by default) similar to "(Someone) slapped Bob with 0 damage"
; 2 - FULL Output to players similar to "Foo slapped Bob with 0 damage"
Offline IcedKnife
« Reply #2 on: July 28, 2014, 05:40:06 pm »
Thanks for the response
Offline Neku
« Reply #3 on: July 29, 2014, 03:13:20 am »
That command is available here: /index.php/topic,7268.0.html
